concox GT06N
Тема: concox GT06N
Hello,
Does anyone have a script or a manual to configure this type of device?
I have a new client using this type of devices, in other plataform but i need an advice to chance them
Thank you
concox GT06N
Re: concox GT06N
photo please !
Spread the AVL- World
concox GT06N
Re: concox GT06N
here its the´picture,
thank you
Иконка вложений 1-130G11F117.pdf 437.5 Кб, файл был скачан 2372 раз(а)
concox GT06N
Re: concox GT06N
All of the configuration settings you can use are in the manual you attached so you should be able to get it operational relatively quickly.
Phoenix Solusi
Mobile Visible Secure
concox GT06N
Re: concox GT06N
thank you John G
concox GT06N
Re: concox GT06N
Did you get the unit showing up in Wialon OK? Let me know if you need any help.
Phoenix Solusi
concox GT06N
Re: concox GT06N
Hello.
For proper operation of the device you need to configure it by SMS. I'm sending to the device SMS:
SERVER,1,193.193.165.165,20859,0 #
and he answers:
Error: Parametr 2 domain is not formatted correctly!
what to do?
  • concox GT06N
concox GT06N
Re: concox GT06N
danis try to send next command:
SERVER,1,gpsgsm.org,20859,0#
concox GT06N
Re: concox GT06N
yavi пишет:
it worked, thank you
concox GT06N
(08/06/2016 11:16:44 отредактировано danis)
Re: concox GT06N
What is responsible for the input of the ignition ?
Photo data from the device attached.
  • concox GT06N
concox GT06N
Re: concox GT06N
danis Nobody (except you/your installer) knows about which input is connected to ignition circuit wire.
May be this parameter is coded into I/O parameter (I/O=44)
After understanding which input transmits your ignition  I advice you to learn more about "bitwise parameter control".
http://docs.gurtam.com/en/hosting/cms/u … sors/param
concox GT06N
Re: concox GT06N
Hello
Has anyone had problems with the messages you send GT06N when in blind zone?
regards
concox GT06N
Re: concox GT06N
Dears i have GT06N , I have problem with Engine hours  =00:00   thanks to advice how to set Engine hours counter
concox GT06N
Re: concox GT06N
http://nyomkoveto.top5.hu/img/gt06-N/GT … ancsok.pdf
Command list for all device Concox GT06xx
Julio R. | Gerente de Producto Telematics
concox GT06N
Re: concox GT06N
Hello
If the device is  in offline mode is there any command to know whether the device is manually disconnected or some other problem like GSM issue.
concox GT06N
Re: concox GT06N
Can anyone assist, gt06n
send - server,1 gpsgsm.org, 20859, )#
error: parameter 1 (0/1)
send - server, 0, 193.193.165.165, 20859, 0#
what am i doing wrong
concox GT06N
Re: concox GT06N
matthewcpt пишет:
We send same exactly as: SERVER,0,193.193.165.165,20859,0# and always works fine for us.
We send APN & Timer command first then Server command.
Silly question maybe but is it a matter of "UPPERCASE"? I have no units here at present to test on to know.
Regards
Onwards and Upwards!!
concox GT06N
Re: concox GT06N
Hello!
Concox GT06 as some other Concox devices now can be mouse-click configured when connecting via flespi to Wialon. Even without conection you may use SMS-based configuration for the same settings from flespi. Want to remind that this is totally free for use.
Please follow detailed instructions in order to put flespi between Wialon and device.
concox GT06N
Re: concox GT06N
buen dia comunidad gurtam-wialon
tengo un problema con estos equipos CONCOX en general, cuando estan fuera de cobertura GPRS (fuera del país) o en zona de frontera pierden la señal como es lógico, pero siguen almacenando la información sin problema.
Particularmente, sucedió que duró tres días un dispositivo en otro país, y cuando se conectó de nuevo Wailon recibió la información como si todo el recorrido de tres días hubiese sucedido en menos de 5 minutos, minutos en los que tardó en subir al servidor la información alojada en memoria.
En afán de verificar, configuré el mismo dispositivo al servidor original TRACKSOLID.COM y luego de varios días sin cobertura, evidenció que al retomar la conexión si coinciden las horas y el kilometraje.
Quisiera saber si alguno ha evidenciado el mismo problema
Gracias, agradezco aportes
Lps Trackers
concox GT06N
Re: concox GT06N
lpscolombia
Buenos días,
Mándenos por favor el nombre de la unidad y el tiempo cuando sucedió lo descrito a support@gurtam.com
Gracias
concox GT06N
Re: concox GT06N
GRACIAS COLEGAS
les comento que acabo de hacer pruebas con el equipo en cuestión, pero hice las pruebas en la plataforma del fabricante, lo dejé tres horas sin GPRS y al restablecerle la información fue graficada correctamente, como era de esperarse,
voy a insistir en gurtam y espero que se llegue a una solución, pues tengo buena cantidad de equipos de esa marca, me vería bastante afectado.
les estaré comentando
Lps Trackers
concox GT06N
Re: concox GT06N
Gracias, ya retomo contacto y planteo nuevamente el caso, ya había sido cerrado, preferiría que fuera mejor tratado por skype si es posible
usuario: gerson_lpscolombia
quedo atento
yuhr пишет:
lpscolombia
Buenos días,
Gracias
Lps Trackers
concox GT06N
Re: concox GT06N
lpscolombia Acabo de enviarle un email para seguir el tema en el ticket original.
Espero su respuesta.
Gracias
concox GT06N
Re: concox GT06N
I am having the same issue as lpscolombia.
It appears that all 'old data' (stored data during no GPRS) have the same timestamp when being pushed back to the server after GPRS are re-established. *see attached picture.
I opened a support ticket and from the log it seems that it was sent that way by GT06N. There has to be a way to deal with this as I understand that in Tracksolid (the original platform), there is no such issue. It might be related to 'Information Serial Number' in its protocol doc or maybe there is something wrong in the integration.
I will try to email the hw guys and see if they can help.
  • concox GT06N
concox GT06N
Re: concox GT06N
bhalim, Concox devices contain configurable timezone setting that generates different time then server can expect. Some servers, e.g. flespi can read it from device during connection stage, some expects it in UTC timezone.
I recommend you to change this setting to UTC (zero) timezone to prevent any troubles in the future with any kind of server.
