Topic: How to create a unit from WLP file using javascript api in kit?
I am trying to a unit from WLP file using javascript api in kit
I have Successfully created a unit using javascript with following code
var name=$("#nm").val();
var hwid=$("#hw").val();
var user=sess.getCurrUser();
wialon.core.Session.getInstance().createUnit(user,name, hwid,1152921504606846975,function (code,obj) { // login callback
if (code){ alert(wialon.core.Errors.getErrorText(code)); return; }
oid=obj.getId();
Then i tried to update the unit parameters using the following code
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<title>Wialon Playground - Import resource props</title>
<script type="text/javascript" src="http://code.jquery.com/jquery-latest.min.js"></script>
<script type="text/javascript" src="https://kit-api.wialon.host/wsdk/script/wialon.js"></script>
</head>
<body>
<style>
.btn {
cursor:pointer;
div {
margin-bottom:20px;
#log_cont {
background-color: #EEEEEE;
height: 150px;
overflow-y: scroll;
font-size:75%;
#log_cont table {
width:100%;
</style>
<div id="base">
<div>
Append resource props to: <select id="resource" name="resource"><option value="">-- select resource --</option></select><br/>
From file: <input class="btn" type="file" name="import_file" id="import_file"><br/>
<input class="btn" id="btn_import_wlp" type="submit" value="Upload & Import">
</div>
Data to import:
<div id="prop_types"></div>
Log:
<div id="log_cont">
<table>
<tbody id="log"></tbody>
</table>
</div>
</div>
var importWLP = {
// generate needed res props system data
prop_types: {
poi: {
library: "resourcePois",
dataFlag: wialon.item.Resource.dataFlag.poi,
editFlag: wialon.item.Resource.accessFlag.editPoi,
methodCreateItem: "createPoi",
printName: "POIs"
zones: {
library: "resourceZones",
dataFlag: wialon.item.Resource.dataFlag.zones,
editFlag: wialon.item.Resource.accessFlag.editZones,
methodCreateItem: "createZone",
printName: "Geofences"
jobs: {
library: "resourceJobs",
dataFlag: wialon.item.Resource.dataFlag.jobs,
editFlag: wialon.item.Resource.accessFlag.editJobs,
methodCreateItem: "createJob",
printName: "Jobs"
notifications: {
library: "resourceNotifications",
dataFlag: wialon.item.Resource.dataFlag.notifications,
editFlag: wialon.item.Resource.accessFlag.editNotifications,
methodCreateItem: "createNotification",
printName: "Notifications"
drivers: {
library: "resourceDrivers",
dataFlag: wialon.item.Resource.dataFlag.drivers,
editFlag: wialon.item.Resource.accessFlag.editDrivers,
methodCreateItem: "createDriver",
printName: "Drivers"
trailers: {
library: "resourceTrailers",
dataFlag: wialon.item.Resource.dataFlag.trailers,
editFlag: wialon.item.Resource.accessFlag.editTrailers,
methodCreateItem: "createTrailer",
printName: "Trailers"
reports: {
library: "resourceReports",
dataFlag: wialon.item.Resource.dataFlag.reports,
editFlag: wialon.item.Resource.accessFlag.editReports,
methodCreateItem: "createReport",
printName: "Reports"
init: function () {
// flags to specify what kind of data should be returned
var flags = wialon.item.Item.dataFlag.base;
for (var i in this.prop_types) {
sess.loadLibrary( this.prop_types[i].library );
flags = wialon.util.Number.or(flags, this.prop_types[i].dataFlag); // 64 bit OR
$('#prop_types').append('<input type="checkbox" checked="checked" name="'+i+'"> '+this.prop_types[i].printName+'<br>'); // construct prop types checkboxes
// Subscribe on resource data
[{type: "type", data: "avl_unit", flags: flags, mode: 0}], // Items specification
function (code){ // updateDataFlags callback
if (code) {
importWLP.log("Error: "+wialon.core.Errors.getErrorText(code));
return; // exit if error code
importWLP.res = sess.getItems("avl_unit"); // get loaded 'avl_resource's items
for (var i = 0; i < importWLP.res.length; i++) {
$('#resource').append('<option value="'+ importWLP.res[i].getId() +'">'+ importWLP.res[i].getName() +'</option>');
$('#btn_import_wlp').click( function(){ importWLP.importFromFile.apply( $('#import_file')[0] ) } );
importFromFile: function (event) {
var res_id = $('#resource').val(),
filter = [];
if ( !res_id ) {
alert('Select resource to import to');
return false;
$('#prop_types input[type="checkbox"]:checked').each(function(){
filter.push( $(this).attr('name') );
if ( !filter.length ) {
alert('Select prop types to import');
return false;
alert(res_id);
importWLP.log('Import start...');
// this - is input type="file"
wialon.exchange.Exchange.importJson([this], function(code, fileData){
if (code) {
importWLP.log('Error('+code+')');
return;
var res = wialon.core.Session.getInstance().getItem(res_id); // get resource by id
var user_access = res.getUserAccess();
// iterate through uploaded files
wialon.core.Remote.getInstance().startBatch();
for (var f in fileData.files) {
// iterate through props
for (var res_type in importWLP.prop_types) {
// check resProp exists and items are in array
if ( typeof fileData.files[f][res_type] != 'undefined' && $.isArray( fileData.files[f][res_type] ) && fileData.files[f][res_type].length ) {
if ( !wialon.util.Number.and(user_access, importWLP.prop_types[res_type].editFlag) ) {
importWLP.log('You don\'t have access to edit '+ res_type +' in ' + res.getName());
continue;
// iterate through prop items
for (var i in fileData.files[f][res_type]) {
// create needed prop
res[ importWLP.prop_types[res_type].methodCreateItem ]( fileData.files[f][res_type][i], function(code, data) {
importWLP.log('Created ' + ( (data && typeof data.n != 'undefined') ? "'" + data.n + "'" : 'prop') + ' ' + (code ? 'Error('+code+')' : 'Ok'));
wialon.core.Remote.getInstance().finishBatch(function(){
importWLP.log('Import completed successfully');
$('#resource').val('');
log: function(msg) {
var $log = $('#log'),
$log_cont = $('#log_cont');
$log.append('<tr><td>' + msg + '</td></tr>');
$log_cont.animate({
scrollTop: $log_cont[0].scrollHeight
}, 300);
// execute when DOM ready
$(document).ready(function () {
wialon.core.Session.getInstance().initSession("https://kit-api.wialon.host"); // init session
// For more info about how to generate token check
// http://sdk.wialon.host/playground/demo/app_auth_token
wialon.core.Session.getInstance().loginToken("xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", "", // try to login
if (code) {
importWLP.log(wialon.core.Errors.getErrorText(code));
importWLP.init(); // when login suceed then run init() function
</script>
</body>
</html>
but it stops while importing WLP and does not respond afterwards
Please help me with this
i am attaching the WLP file i used
Thanks
