Quecklink GL505?
Topic: Quecklink GL505?
Hi Guys,
seems that i am stupied and dont understand how to update FW in quecklink gl505 device.
i have the firmware (.bin) file, the config cable , the configuration software, but i dont find any point in config software to upgrade the firmware...
heeeeeelp
Wolf.
Quecklink GL505?
Re: Quecklink GL505?
Hello wwbusch,
based on other models i've updated please try this,  unplug the programming cable from device (not from computer !) start the updater software
1.- select proper device
2.- select correct com port and speed (115200)
3.- select cat file (this file is under your fw directory release)
at this point you can plug in the cable at device side and
4.- press start
Quecklink GL505?
Spread the AVL- World
Quecklink GL505?
thanks! So if someone need latest FW and Updater for the devices, just let me know.
Wolf.
