Nearest Units Tool
Topic: Nearest Units Tool
Hello !
I have found the Nearest unit tool critically important for dispatchers mainly to resupply in the field, but unfortunately POI data will not load in search addresses combo box. Having this simple enhancement will boost the significance of the tool as dispatchers mostly rely on POIs mainly in case of countries with  not as such organized addressing system. please consider including it !
Nearest Units Tool
Re: Nearest Units Tool
Thank you, nasnew, this is an interesting point. We'll consider it.
Katerina Alexandrova
Product Manager (Mobile)
Nearest Units Tool
POI and Geofences should be a great enhancement indeed in the nearest unit tool !
Nearest Units Tool
OK, guys, your point is clear. However, I have a question for you. If a circle-shaped geofence has radius (and it certainly will), should we:
a) find nearest units to its centeral point
OR
b) find nearest units to any of its borders.
That is the question! (c)
Nearest Units Tool
In my opinion in case of Geo-fence, it should be checked against the boundary.
