Topic: GuardMagic VB8
GuardMagic VB8,- Special GPS-GPRS vehicle module for fuel transportation companies. Support up to THREE regular fuel tanks and up to 11 cargo fuel tanks (fuel sensor with digital interface). Two Fuel buses (EIA-485). Universal communication protocol.
GuardMagic VB8 is a compact special tanker-truck GPS/ GSM-GPRS module dedicated to use on tanker-truck application.
GuardMagic VB8 intended for remote monitoring fuel level in compartments of fuel trailer (semi-trailer), remote supervision of tanker-truck movement, monitoring of tractor (tuck) fuel consumption.
GuardMagic VB8 benefits in brief:
- support up to ELEVEN fuel level sensors in cargo tanks (support up to eleven cargo tanks or fuel compartments);
- support up to THREE fuel level sensors in tractor regular tanks (support up to three regular tanks);
- support up to SIX fuel quality sensors (density/viscosity or water activity);
- digital industrial communication interface with all fuel level sensors (EIA-485);
- two digital communication bus with fuel level sensors;
- collect information from fuel level sensors: fuel level and temperature;
- high resolution in fuel bus (1024 or 4096 levels);
- fuel bus diagnostic;
- internal non-volatile memory for the about 110 thousands of records;
- driver identification function;
- connection up to SEVEN temperature sensors;
- programmed active stand-by mode;
- growing functionality.
Using the information transmitting by GuardMagic VB8 about fuel level in fuel compartments, tanker-truck location and parameters of its movement, speed information, information from additional external sensors is possible to:
- control a fuel tanker-truck location;
- check loading a fuel trailer (fuel level);
- control a fuel level in trailer fuel compartments;
- check the point of fuel loading and uploading;
-check parameters of movement and real run of tanker-truck and safety driving;
- check tractor (truck) real fuel consumption;
- check up volume of fueled fuel in to truck tanks and cargo tanks, and determine the fact of fuel drain;
- check the temperature from fuel level sensors ot temperature sensors;
- personalize the active driver;
- determine start/end of loading/unloading of a tanker-truck;
- check the use of working hours;
- etc.
Download:
GuardMagic VB8 leaflet = http://guardmagic.com/01-engl/91e-downl … let-01.pdf
Guardmagic VB8 functionality table = http://guardmagic.com/01-engl/91e-downl … 02-10_.pdf
