Unit creator name
Topic: Unit creator name
Hi, I am trying to find unit creator name + some other info for units.
If I run update_data_flags with flag = 105, I get unit creator ID
wialonurlfix + "/ajax.html?svc=core/update_data_flags&sid=" + eID +
               "&params={" +
                   "\"spec\":[" +
                       "\"type\":\"type\"," +
                       "\"data\":\"avl_unit\"," +
                       "\"flags\":0x00000105," +
                        "\"mode\":0" +
The problem is that I cant match the ID of the creator with none of the users IDs below when I search them like:
https://hst-api.wialon.host/wialon/ajax.html?svc=core/search_items&params={"spec":{"itemsType":"user","propName":"sys_name","propValueMask":"*","sortType":"sys_name"},"force":1,"flags":1,"from":0,"to":0}&sid=
In other words, I know my unit creator ID, how should I find creator name?
Thanks !
Unit creator name
Re: Unit creator name
You're doing everything alright
Note, that current user not included in core/search_items result
Try to use core/search_item instead
If no result - you havent rights to creator and cant get its name
Unit creator name
right into the bulls eye smile thanks !  core/search_item did what I needed
Unit creator name
Shmi,
thanks for helping so fast.
Wolf.
