Execute commads via remote API (tcp opton)
(edited by gchumbes 17/12/2013 20:30:58)
Topic: Execute commads via remote API (tcp opton)
hi, we are trying to execute commands (send commands) via remote API and we got error 4, we send following sentence:
:https://hst-api.wialon.host/wialon/ajax.html?svc=unit/exec_cmd&params={"itemId":7004974,"commandName":"custom_msg","linkType":"tcp","param":"SSSXP11","timeout":10,"flags":0}&sid=b31d80f53b6dc6b7649f2dd69672302a
but we received error 4 (i understand is input error), do we have any syntax problem? we use custom_msg.
any suggestion would be very helpfull
regards
Gustavo Chumbes
Re: Execute commads via remote API (tcp opton)
I have no idea  what the problem is. You can write me a personal message and point login and password for checking this request.
Development Department
Currently we have exactly the the same problem. Everything else over API works but not execution of the commands. We have checked everything like permissions etc but I think this is something else that we can not really find what it is.
gchumbes, have you solved the problem and could you please post what was the problem?
Maybe Gurtam guys know how to solve this error: 4 issue while executing commands over API?
Thanks.
gpser
To execute command you need only 2 request:
1) Create
2) Execute
Just tested and everything works well for me
Can you provide a little bit more information about your problem?
(edited by gpser 11/01/2016 10:48:22)
We are not trying to first Create a command, we are executing it without prior creating any command. Do we need to create it first?
Well, we are trying to execute a command like this:
http://sdk.wialonpro.com/ajax.html?svc=unit/exec_cmd&params={"itemId":3798,"commandName":"Fall_Down_Alarm","linkType":"tcp","param":"123456F1","timeout":20,"flags":0}&ssid=4003231d4766a13d733b1c8dba72e6e2
Unfortunately, you are not allowed to view this text
Can you please give me example that you know should work? As parameter you can write anything just give us an example.
Sorry, all my comments about Hosting
+ show spoiler
Logic is straightforward:
* create command once (using unit/update_command_definition)
* after creation execute it as many time as you want (using unit/exec_cmd). commandName should be same that you used
while command creation.
It does not work!
Getting "error: 4" even while I am issuing command unit/update_command_definition
http://sdk.wialonpro.com/ajax.html?svc=unit/update_command_definition&params={"itemId":3798, "id":123, "callMode":"create", "n":"fall_alarm", "c":"custom_msg", "l":"tcp", "p":"123456F1", "a":"0xfffffffffffffff"}&ssid=3785df7e66b3a8fd14287bac7537415d
I didn't know what to write as id so I just typed 123. I don' know if this is needed during command creation?
gpser, use unit/update_command_alias request in pro with your parameters.
Parameter id is ignored in creation mode.
