Working with svc=resource/update_notification, remoteapi command
(edited by glizarraga 04/10/2013 21:07:02)
Topic: Working with svc=resource/update_notification, remoteapi command
I am trying to create a new notification when an event occurs, but got stocked, it keeps showing error=4, I have two days gueezing what the problem is, here is the url:
https://kit-api.wialon.host/wialon/ajax.html?svc=resource/update_notification&params={"itemId":764053,"id":"","callMode":"create","txt":"","un":[821962],"trg":{"t":"geozone","p":{"geozone_ids":"1","type":"1"}},"act":[{"t":"message","name":"Entro o salio de geo1"},{"t":"event","flags":"0"}]}&sid=7ba1e609456716433b952aa32c91d439
I got the documentation here
http://sdk.wialon.host/wiki/en/sidebar/r … tification
http://sdk.wialon.host/wiki/en/sidebar/r … ation_data
Thanks!
Re: Working with svc=resource/update_notification, remoteapi command
Error 4 means a     Invalid input
http://sdk.wialon.host/wiki/en/kit/remot … ors/errors
In your request notification ID is empty : ,"id":""
You should set any number of id when you create a notification
Also you should set other required parameters: name, text of notification and so on
http://sdk.wialon.host/wiki/en/kit/remot … ation_data
Hi, Thanks for your atention.
I am still getting the error, here is the params i´m using.
?svc=resource/update_notification&params={"itemId":"764053","id":"1","callMode":"create","n":"tea","txt":"asdas","ta":"1381196227","td":"1412732227","ma":"1","mmtd":"3","cdt":"3","mast":"3","mpst":"2","cp":"3","tz":"7","la":"es","ac":"4","fl":"0x0","un":["1093167","774390","816212","821962"],"trg":{"t":"geozone","p":{"geozone_ids":[1],"type":"1"}},"act":[{"t":"message","name":"teaaa"},{"t":"event","flags":"0"}]}&sid=6ff759df439e31c1843f2f0a74cf811d
Please look attentively which type has every parameter. Everywhere you put text but sometimes int is needed. Also you didn't put parameter sch at all.
Development Department
Hi! thanks again. I put all parameters in its respective format, and added sch parameter. But im still getting the error: 4.
Is there a way to look at wich param am I failing? This is my last URL params: ?svc=resource/update_notification&params={"itemId":764053,"id":1,"callMode":"create","n":"tea","txt":"asdas","ta":1381196227,"td":1412732227,"ma":1,"mmtd":3,"cdt":3,"mast":3,"mpst":2,"cp":3,"tz":7,"la":"es","ac":4,"fl":0,"sch":{"f1":1,"f2":2,"t1":1,t2:2,"m":3,"y":2014,"w":5},"un":[1093167,774390,816212,821962],"trg":{"t":"geozone","p":{"geozone_ids":[1],"type":1}},"act":[{"t":"message","name":"teaaa"},{"t":"event","flags":"0"}]}&sid=21e3877d3d9ee0c91353e9ffd5f41450
Parameter act should be of  following format:
act: [{
    t: <text>,
    p: {}
act: [{
    t: <text>,
    p: {}
Finally worked!! thanks!
