TrackPro TR-20
(edited by taliban 12/07/2013 00:35:15)
Topic: TrackPro TR-20
Hello, I am novice user of Wialon PRO.
The query is how to configure the gps tracker TrackPro TR-20, or find an alternative.
http://www.sztrackpro.com/Products.html
I understand that used TrackPro GlobalSat modules. sms commands are as follows:
First,modify unit ID,send this command:
&&Z13, 200707
200707 is the new unit ID, you can set any new ID by yourself.
then set the APN, send this command:
&&******,Z10,[APN],[user name],[password]
For example: &&200707,Z10,internet.movistar.mx,movista,movistar
If succeeded, the tracker will reply one message with Z10
Then set IP and port, send this command:
&&200707,Z39,1,121.37.60.19,1167,1
If succeeded, the tracker will reply one message with Z39
Thirdly, set the fixed time report, send the command:
&&200707,Z31,30,1
If succeeded, the tracker will reply one message with Z31
MUCHAS GRACIAS
TrackPro TR-20
Re: TrackPro TR-20
Hi Forum,
Is any one using this Tracker ?   TrackPro TR-20 ?
regards
Baltika
