Teltonika FM5300
Topic: Teltonika FM5300
Hello
I'm having trouble using GPRS Commands on Teltonika FM5300, I tried to use a simple one likes #GET VERSION but the system show me that there isn't available command, if somebody have any idea how to use it? Could you help me?
Regards.
Jorge Baeza
Teltonika FM5300
Re: Teltonika FM5300
I have problem like this with FM1100 . Problem is cause firmware for retail is not support GPRS command .
contact teltonika for special firmware and configulator tool .
Teltonika FM1100 firmware with GPRS command accepted
Teltonika FM5300
Yes, we already ask for it before, but the manual says that FM5300 has GPRS available.
Actually do you use FM1100 with gprs command? We need to send commands by TPC and it's very important to know if FM works from 1100 until 5300 because we use 4 different models.
Best Regards.
Jorge Baeza
Teltonika FM5300
GPRS commands can only be sent when the unit is connected to Wialon in a session otherwise the target IP of the device is not known. If the session does not exit you need to send an SMS.
Regards
John
Phoenix Solusi
Mobile Visible Secure
Teltonika FM5300
Hello.
i'm searching for protocol for teltonika FM5300 and FM300, any one have it out there?
Many Thanks
Spread the AVL- World
Teltonika FM5300
Hello
What do you mean about protocol?
Is it config file to FM5300 or just manual?
about it you can try request here Teltonika FM5300&p=10
If you would like to have the communication protocol you should request only to manufacturer
Also what is model FM300 ? it's not from Teltonika.
Teltonika FM5300
chdi wrote:
Hello
the correct ones are FM5300 and FM3300, and yes i want the communication protocols so we can some test on local server, actually Teltonika is a very hard company to work with...
thanks in advance
Teltonika FM5300
ye, I know...But only the manufacturer can provide a official communication protocol
You can try to find some documentation on their site. http://www.teltonika.lt/en/pages/view/?id=33
Teltonika FM5300
Ok,
Thank You chdi  !!
Teltonika FM5300
configurator only....
http://www.4shared.com/file/H7bOFY1W/a1 … rator.html
Teltonika FM5300
try to restart it.
Teltonika FM5300
I have teltonika fm5300 and there is no option to upload cfg if I set it up like fm42 then there is an option for sending cfg but  when device is connected this command is not availible.
GPRS commands?
Is this possible
Teltonika FM5300
Hi Aahero,
as i know upload of configuration is ONLY possible via a little tool, Eduard Vald from GoGPS developed.
Maybe you ask him, he is the specialist in Teltonika remote CFG Upload.
Wolf.
Teltonika FM5300
Are you looking to upload the firmware or just to change certain configuration parameters on an operating unit?
Phoenix Solusi
Teltonika FM5300
Just to change certain config parameters
Thanks
Teltonika FM5300
Configuring Teltonika FM5300, FM4100, FM4200 devices via TCP/IP is now available in Wialon.
The process of configuring via TCP includes the following stages:
1) the server (Wialon) sends a binary SMS to the device.
2) the device connects to the server (Wialon) to receive configuration.
3) the server (Wialon) sends configuration to the device.
4) the device breaks the connection.
User must create SMS command Upload configuration (upload_cfg) in Wialon and upload a configuration file while creating or sending the command.
Configuration file must have a certain format described in the Instruction on configuring via TCP the link to which is placed on FM5300 page on www.gurtam.com:
http://gurtam.com/en/gps_tracking/gps_h … ?id=260225
The Instruction:
http://extapi.wialon.host/hw/cfg/teltoni … tcp_en.pdf
Teltonika FM5300
Registration of parameters for LBS Detector has been added for Teltonika FM1100, FM1200, FM5300
Teltonika FM5300
Do you know of any rfid reader device that works with fm5300 and winlon? I tried using one that emulates 1wire, but it sends id information only in 1% of cases.
Teltonika FM5300
(edited by ORMAT India 24/04/2015 19:00:56)
You may be interested in checking out 1-Wire® RFID Reader by ORMAT.
It emulates iButton. Best feature is the Buzzer & Bi-color LED on successful RFID read. It works even with the Teltonika basic line trackers FM11XX/12XX !
Works great with all popular 125 kHz RFID cards (Manchester Encoding / EM cards). It is being used with FM12XX for In-Vehicle attendance.
Note that this RFID reader doesn't support HID cards.
Teltonika FM5300
Hi,
I am trying to get FM5300 connected to my server via UDP.
I am getting the data at the server, but the problem for me is that the device always sends the previously read data also.
As per the documentation,the server need not acknowledge the data if the packet type is 1.
Also, I have a doubt in sending the acknowledgement. what should be sent as acknowledgement?
I am using PHP at the server.
21
Teltonika FM5300
Hi Sajipg,
its very easy: just contact your local Teltonika Employe to provide you with actual protocol documentation.
I dont think that Gurtam / or Gurtam Partners will help you in creating a competition platform ;-)
If you need contact details, let me know.
Wolf.
22
Teltonika FM5300
Thank you for the response.Could you please send some contact information of somebody in Teltonika to discuss the protocol?
23
Teltonika FM5300
(edited by Baltika 13/08/2015 11:54:53)
HQ JSC Teltonika
Saltoniskiu st. 10c
LT-08105, Vilnius, Lithuania
Tel: +370 5 212 74 72
Tel: +370 5 265 73 60
Fax: +370 5 276 13 80
Email  info@teltonika.lt
Web   http://www.teltonika.lt/
24
Teltonika FM5300
by the way, for those who want to add the protocol: the costs is only one time fee of 200 Euro! you should spend that and get support for that... much cheaper than pirated copies of old protocols and re-engineering it!
Wolf.
25
Teltonika FM5300
Hello guys.
Any ideea if this solution from teltonika http://www.teltonika.lt/en/pages/view/?id=1041 works  with gurtam?
I am interested in reading data from  VDO 1381 tachograph and show it using Tachoviewer.
Has anyone tried it yet?
Thanks!
