Topic: GuardMaguc fuel level sensor (with digital communication interface)
GuardMagic DLLS1a - Robust Electronics Fuel and Oil Level Sensor with digital communication interface EIA-485 for standard and heavy application. Resolution 1024 or 4096 levels. Available sensor length from 300mm and up to 3000mm.
GuardMagic DLLS1b - Robust Electronics Fuel and Oil Level Sensor with digital communication interface EIA-485 for standard and heavy application. Resolution 1024 or 4096 levels. Communication interface retranslation. Available sensor length from 300mm and up to 3000mm.
GuardMagic DLLS1ct - Robust Electronics Fuel and Oil Level Sensor with digital communication interface EIA-485 for standard and heavy application. Resolution 1024 or 4096 levels. Connection to GuardMagic JBB01 barrier.
Avaikable sensor length: 1300mm, 1500mm, 1700mm, 2000mm, 2500mm, 3000mm.
GuardMagic DLLE1ct - Robust Electronics Fuel Level Sensor with EIA-485 communication interface for application in hazardous area. For standard and heavy application. Resolution 1024 or 4096 levels. Available sensor length from 1300 mm and up to 3000 mm. Operation only with GuardMagic JBB01 (intrinsically safe barrier).
