Wialon API in Python
Topic: Wialon API in Python
Hello guys
Im facing some troubles trying to automate a data extractin using Wialon API.
Every time I test it on Postman it works but when Im try it python I always receive the error 1
Can some one help me ?
The request Im trying is this one
svc=report/get_result_rows&params={\"tableIndex\":0,\"indexFrom\":0,\"indexTo\":10}\"&sid=MYSID
Kind Regards
Re: Wialon API in Python
joao.lauro.de.marco hello, presumably, the error related to the encoding in this part }\"&sid
Please, send full request text used in your app.
Anton Zinovyev
Technical Care Engineer (L2)
Wialon
Hello Gurtam,
this in a part of my code, Im using the requests library to make the reques
headers = {"sid":MYSID}
new_url_info = 'https://hst-api.wialon.host/wialon/ajax.html?svc=report/get_result_rows&params={"tableIndex":0,"indexFrom":0,"indexTo":4}'
resposta2 = requests.get(new_url_info,  headers=headers)
joao.lauro.de.marco hello, the sid is a part of the parameters. If you use request library, you can pass the sid directly in params. Also, the request should be executed as post, not get.
For example:
import requests, json
base_url = 'https://hst-api.wialon.host/wialon/ajax.html'
response = requests.post(base_url, params={
    'svc': 'report/get_result_rows',
    'sid': 'SID',
    'params': json.dumps({
        "tableIndex":0,
        "indexFrom":0,
        "indexTo":4,
response_data = response.json()
Anton Zinovyev
Wialon
