Events
(edited by hhamedk 26/07/2021 18:25:49)
Topic: Events
Hi GT
I need to receive events for a past period and call:
svc=events/load&params={"itemId":XXX,"ivalType":1,"timeFrom":1626035340,"timeTo":1626381059,"detectors":[{"type":"trips", "filter1":0},{"type":"speedings", "filter1":0},{"type":"fueling", "filter1":0},{"type":"fuel thefts", "filter1":0}]}
And then:
svc=events/get&params={"selector":{"type":"trips,speedings,fueling,fuel thefts","timeFrom":1626035340,"timeTo":1626381059,"detalization":7}}
But the problem is that for fuel fillings and fuel thefts we don't receive any data while the Wialon itself shows them in same interval. The response contains the related parts but those are always empty (0):
    "events": {
        "fuel thefts": {
            "0": 0
        "fueling": {
            "0": 0
        "speedings": {
            "0": 0
        "trips": {
            "0": 28
    "states": {
        "fuel thefts": {
            "updateTime": 0
        "fueling": {
            "updateTime": 0
        "speedings": {
            "updateTime": 0
        "trips": {
            "updateTime": 1626035340
    "selector": {}
    "fuel thefts": {
        "0": []
    "fueling": {
        "0": []
Please let us know what's wrong with our requests.
Events
(edited by hhamedk 26/07/2021 19:37:14)
Re: Events
Another Problem is Speedings. Sometimes response is 0 while as we check speedings easily with Wialon web and executing track for same period there are many speedings. Sometimes difference in numbers of speedings. I thought there may be some difference between the logic of speedings in tracks and requesting them via API with events command. I checked with Wialon Android and found what I'm getting via API is also different from what Wialon Android shows. Please explain what is the source of this problem. Why I see events in Wialon Android and Web that those are not available via API call. Is that a bug or I'm doing something wrong.
**Update**
I'm not sure but seems problem with speedings appear only in WL
Events
Re: Events
Hi Hamed,
there is not events in Wialon like fueling,fuel thefts
To get fuel information you need to specify event type 'lls' - where "filled" value positive is filling, negative is theft
consumption - fuel consumption.
Re: Events
Hi, we have the same problem. Any help about the issue? I specified lls, but still, I am not able to bring historical events data
Events
Re: Events
javid.balakishiyev hello, please, send the email to support@wialon.host and specify the units example. Then we will be able to check the situation.
Anton Zinovyev
Technical Care Engineer (L2)
Wialon
