Topic: Filter disable for TPMS data msgs with parameter shown as sensor value
I am trying to use the filter function in the sensor values messages type, but this filter is disabled for data messages with the
parameters shown as sensor values
https://docs.wialon.host/en/hosting/user … ges_filter
The sensor values is very important for TPMS tyre pressure management, especially when values need to be checked over time
Can the filter be enabled for data message with parameter shown as sensor values?
Example: I would like to select a specific sensor and filter all the empty readings out to make the list shorter
