Genset ISsue
Topic: Genset ISsue
Which devices should i install in Gensets which also generates Kwh with engine hours
Genset ISsue
Re: Genset ISsue
Hi
I suppose genset may have power meter already. Or you can install it.
There are many power meters with rs485 interface, try to find power meter with rs485 modbus RTU interface
Proper gps tracker can read modbus data.
eurosenstelematics.com
Genset ISsue
Re: Genset ISsue
mechatronica Hello
If i use energy meters and will get data then how can i mapped or how can i show that data in wialon monitoring panel what query should i write in templates?
Genset ISsue
Re: Genset ISsue
nowucsm wrote:
mechatronica Hello
I am sorry, it seems you better start from basic projects
