Topic: Driver Login ApI
We are developing the new mobile app for the drivers. Which API we have to use to login as driver using mobile number.
I am using the above request to driver login. but it's returning {error:1}
Hello. Try to escape params according to application/x-www-form-urlencoded format, like:
https://hst-api.wialon.host/wialon/ajax.html?svc=resource%2Fdriver_operate¶ms=%7B%22phonenumber%22%3A%22%2B919500502190%22%2C%22password%22%3A%22******%22%2C%22callmode%22%3A%22status%22%7D
Rual still no luck i am getting the same error. do we need to pass the sid for the api.
Sorry for previous wrong answer (was removed).
Your request is almost valid. Parameter names are case-sensitive, replace phonenumber with phoneNumber and callmode with callMode.
sid is required if callMode != status.
rual it's working perfectly. thumbs up mate.
