API sharing
Topic: API sharing
Hi
  I need help for API sharing as per the documentation  I created API for our customer he need store the date in his serve.
https://hst-api.wialon.host/wialon/ajax.html?svc=token/login&params={"token":"TOKEN"}
Its working fine I checked it by putting it into browser.
Now how would my customer will find out Lat, Long and time from it
Please help me to short it out so that we can share the data with customer
Thanks and Regard,
Rajeev Kumar
API sharing
Re: API sharing
If you need just latest lat/lon of some unit, you can use core/search_item with id of this unit and flags = 0x1 | 0x400000 = 4194305.
If you need multiple units or don't know their ids, use core/search_items. Example.
For real-time position monitoring, there is core/update_data_flag and /avl_evts. Examples.
API sharing
(edited by rual 04/10/2019 09:34:43)
Re: API sharing
Dear Rual,
Thanks for your kind help
Can you please help me to provide what IP format I have to set like this way.
https://hst-api.wialon.host/wialon/ajax.html?svc=report/exec_report&params={"reportResourceId":ENTER RESOURCE ID HERE,"reportTemplateId":ENTER REPORT TEMPLATE ID HERE,"reportTemplate":null,"reportObjectId":ENTER UNIT ID HERE,"reportObjectSecId":0,"interval":{"flags":16777216,"from":1561098120,"to":1561184579}}&sid=ENTER SID HERE
This is the API link Which I generated.
https://hst-api.wialon.host/wialon/ajax.html?svc=token/login&params={"token":"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"}
I need to share the the API to customer so he can get the real time monitoring of all 62 vehicles
I will be very tankful for this kind help.
Thanks Regards
Rajeev
Edited by rual: do not share tokens on the forum, it is possible to login to your account with it.
API sharing
Re: API sharing
Ok thanks, We will take care of it next time please.
API sharing
Re: API sharing
Can you help Me for this
API sharing
Re: API sharing
Can you please help me in it.
