error 1
Topic: error 1
i try to execute this command :
https://hst-api.wialon.host/wialon/ajax.html?svc=core/search_items&params={"spec":{"itemsType":"user","propName":"sys_name","propValueMask":"*","sortType":"sys_name"},"force":1,"flags":1,"from":0,"to":0}&sid="09d193bcf57b5edz3553e39ca375452b70"
But display always the same error  {"error":1}. (Note any command show me this response)
like this exemple :
error 1
Re: error 1
Good afternoon!
{error: 1} means invalid session in "sid" parameter, i.e. this session id died. How did you get session id in your request?
error 1
Re: error 1
i get sid from session storage like the attached file show it, and this is my request :
https://hst-api.wialon.host/wialon/ajax.html?svc=core/search_items&params={"spec":{"itemsType":"user","propName":"sys_name","propValueMask":"*","sortType":"sys_name"},"force":1,"flags":1,"from":0,"to":0}&sid="09d193bcf57b523553e39ca375452b70"
Note that when I use the sid, I receive the same error (error 1 : invalid session)
error 1
Re: error 1
No need to wrap sid into quotes.
