Formula Table On the Template Report
Тема: Formula Table On the Template Report
Hi,
Regarding the formula about calculation info from Trip, Engine hours and Summary template.
could you please info me, how to calculate Liter / Engine Hours on those template table? cause always 0 value after i execute the report.
sample on the picture.
Re: Formula Table On the Template Report
Hello!
Please, clarify, do use calculator with formula? The general formula is [Consumed]/[Engine hours]. But engine hours value in calculator are used in seconds, so you need to convert it to hours, so formula will be like [Consumed]/([Engine hours]/const3600). Use column indicators instead [Consumed fuel] and [Engine hours] https://docs.wialon.host/en/hosting/user … calculator
There is attached picture in your post, so resend it if it is not your issue.
