Check if a unit is inside the perimeter of a geofence
Topic: Check if a unit is inside the perimeter of a geofence
Hi, how can i check if a unit is inside a perimeter of a geofence and get the id and name of that geofence?
Re: Check if a unit is inside the perimeter of a geofence
Hello.
Yo can use the next link to leanrd about your question.
https://sdk.wialon.host/wiki/en/sidebar/ … by_point?s[]=nearest&s[]=point
You may also be able to simply use a geofence based notification and monitor for the alert...or do you want to poll the geofences looking for units in the geofence
Phoenix Solusi
Mobile Visible Secure
