Creation geofence from PHP
Topic: Creation geofence from PHP
Client is trying to create geofence via PHP;
When creating the geofence there is no answer, he thinks it is due to PHP.
With another  type of coneccionts (ip/user/pwd) there are no problems but this type seems to cut the session.
what about other users, what language do they use to "attack" the API?
Thanks
Locating things
Re: Creation geofence from PHP
Hello
We used many language and libraries to communicate with Wialon API. Including PHP. Here's topic about it https://forum.gurtam.com/viewtopic.php?id=6762
PS if you want to get help from programmers - show them some code wink
Sorry;
Client makes:
//Conexión al Token
"http://hst-api.wialon.host/wialon/ajax.h … BF0437%22}";
//Update Zonas
,itemId:123456789,id:0,callMode:create}]https://hst-api.wialon.host/wialon/ajax.html?svc=resource/update_zone&params={"n":"0886001-40086","d":"08860,Castelldefels","id":9,"f":48,"t":3,"w":100,"e":30869,"c":2568583984,"i":4294967295,"libId":0,"path":"","b":{"min_x":1.98077005312,"min_y":41.2852616629,"max_x":1.98315754952,"max_y":41.287062325,"cen_x":1.98196380132,"cen_y":41.286161994},"ct":1519974344,"mt":1519974344}],"itemId":123456789,"id":0,"callMode":"create"} sid=SID_GENERADOR_POR_TOKEN
//Logout
https://hst-api.wialon.host/wialon/ajax. … _POR_TOKEN
When he make sthe call API UPDATE of geofences with the generated SID before, there is a problem, it tells me "there is not conexion" to server.
thanks
Locating things
Here's working version
https://hst-api.wialon.host/wialon/ajax.html?svc=resource/update_zone&params={"n":"088600140086","d":"08860,Castelldefels","f":48,"t":3,"w":100,"c":2568583984,"p":[{"x":1.98077005312,"y":41.2852616629,"r":100}],"itemId":123456789,"id":0,"callMode":"create"}&sid=SID
I deleted not required parameters from your request
b = boundary, Wialon will calculate it for you
libId path = image, not required
ct mt = creation time, modification time
and some more
Hope this helps
locationGPS, do not forget to delete your token. It's like login/password for bot and you posted it on public forum.
yes, I just did it fast...thanks for informing...regards
Locating things
Hi again,
client test your post, he got same problem, he connects got the SID and when calling the update i was not possible already.
Before the Update He added the instruction given to know server state and it was "disconected", so it must be something about my conexion o in the session I uses that kicks me out.
I checked several PHP forum and it is not the first API that with this method (connection with token and validation with autogenerated token) that gives problems with PHP servers.
Do we have any example with other language or examples to check if I am doing it right"?
thanks
Regards
Locating things
Problem is in php code and the question is how exactly your client sends requests
You can check our libraries on GitHub
https://github.com/wialon/python-wialon
https://github.com/wialon/php-wialon
Hello, Client tried and now has this message:
{"error":4,"reason":"WRONG_PARAMS"}
any idea?
thanks
Locating things
any idea?
thanks
Show me your request params.
Hi, attached
Post's attachments
Locating things
hi,
did you have time to check it?
thanks
Locating things
locationGPS, in your request
echo $url= 'https://hst-api.wialon.host/wialon/ajax.html?svc=resource/update_zone&params={"n":"0886001-40086","d":"08860,Castelldefels","id":9,"f":48,"t":3,"w":100,"e":30869,"c":2568583984,"i":4294967295,"libId":0,"path":"","b":{"min_x":1.98077005312,"min_y":41.2852616629,"max_x":1.98315754952,"max_y":41.287062325,"cen_x":1.98196380132,"cen_y":41.286161994},"ct":1519974344,"mt":1519974344}],"itemId":123456789,"id":0,"callMode":"create"} sid='.$json_clientes["eid"];
replace space before sid with &
now seems works but had this error:
["error"]=> int(4) ["reason"]=> string(63) "VALIDATE_PARAMS_ERROR: {itemId: long, id: long, callMode: text}" }
thanks
Locating things
locationGPS, here is your corrected request:
echo $url= 'https://hst-api.wialon.host/wialon/ajax.html?svc=resource/update_zone&params={"n":"0886001-40086","d":"08860,Castelldefels","id":9,"f":48,"t":3,"w":100,"e":30869,"c":2568583984,"i":4294967295,"libId":0,"path":"","b":{"min_x":1.98077005312,"min_y":41.2852616629,"max_x":1.98315754952,"max_y":41.287062325,"cen_x":1.98196380132,"cen_y":41.286161994},"ct":1519974344,"mt":1519974344}],"itemId":123456789,"id":0,"callMode":"create"}&sid='.$json_clientes["eid"];
There were missing parameters id, itemId, callMode.
<?php
use Location\Coordinate;
use Location\Distance\Vincenty;
$coordinate1 = new Coordinate(19.820664, -155.468066); // Mauna Kea Summit
$coordinate2 = new Coordinate(20.709722, -156.253333); // Haleakala Summit
$calculator = new Vincenty();
echo $calculator->getDistance($coordinate1, $coordinate2); // returns 128130.850 (meters; ≈128 kilometers)
Are you looking for Best Gifts and Toys for 3 Year Old girls (Review) in 2020. Get the list of best toys for your 3 years old Girls.
Could you tell me where (which line) you take every single coordinate before you connect all of them in a string?
Thanks for your work!
Are you Looking for Best Baby Bikes or cycles ? Get Reviews and complete details about Best Bikes, Trikes and Striders for Toddlers.
hi
close it.
Thansk
Locating things
