Topic: SANAV device
Hello there,
Im thinking to buy devices from SANAV, but i check the unit list (Device Type) and no SANAV device appear.
It is possible to add device that doesnt exist in "Device type" in unit properties???
Thanx in advance
Hello there,
Thanx in advance
yes, the way is easy:
you organize the device protocol from your SANAV device.
(Typical you need to sign an NDA with them and with Gurtam).
Than you send it to Gurtam Support and ask to impement the "basic" functionality (like location and digital inputs).
After you installed more than 100 units of this type, you ask them to implement also the rest of the functions you need.
After that you can choose the Device in the Device configuration page and use it.
By the way, if you are talking about this device: https://de.sanav.com/gs-819.html
it has super bad gps receiver, is old fashioned and you find much much better devices from large manufactors that are already implemented in Wialon and has much better functions (just to mention companies like BCE, Teltonika, Galileosky, Atrack, Pointer, ERM, and many many other... just have a look at the Hardware List on Gurtam Website and the Numbers... Numbers = device must be good!
Wolf.
