Тема: Restriction Improvements Reports
Dear,
Some of you have problems generating monthly reports above 20 units?
Our users are currently trying to generate reports for example 23 units, 1 Table "Parking", for the period of 1 month, and it is not possible.
Check with support and tell me what it is because they exceed the limits described in the following link:
https://docs.wialon.host/en/hosting/req/req#limitations
I believe that as a habitual user a "VERY IMPORTANT" improvement is that it is possible to generate at least monthly reports without problems of more than 20 units, it is absurd to expose a Client that must decrease the units or reduce the period of analysis in order to generate a monthly report . Do not forget that the objective of this is to make the user easier, not to give more work imagine your client calculating the correct number of units to generate the monthly report or gradually generating and joining all the generated parts to obtain only a monthly report.
I hope it is a necessity for everyone.
Best regards,
Antonio Ayala
