Topic: Locator creation in Wialon SDK?
hi guys,
seems that i am stupied: i dont find any way to create / edit / delete locator links via Wialon SDK?
Thanks a lot
Wolf
hi guys,
Thanks a lot
Wolf
generate locator link is same to generate token with sdk wialon. You must change the wialon hosting app to locator. check this link for more information about.
remote api https://sdk.wialon.host/wiki/en/sidebar/ … ken/update
to create, edit or delete chnage the callmode in the request.
sample code (PHP remote API):
----------params request----------------------------
$parametrosLocator = array(
"callMode" => "create", "app" => "locator", "at" => 0, "dur" => 86400, "fl" => 256,
"p" => json_encode(array("note" => "", "pois" => 0, "zones" => 0, "tracks" => 0)), "items" => array(13809560)
----------execute request----------------------------
$locator = json_decode($wialon_api->token_update(json_encode($paramsLocator)),true);
sample request and response
request
params:{"callMode":"create","app":"locator","at":0,"dur":86400,"fl":256,"p":"{\"note\":\"\",\"zones\":0,\"tracks\":0}","items":[13809560]}
Response
{"h":"d9e673294c64a16afc0cd581fd71596c3EA8019052D397E2371F3F110A80B91306D8D82B","app":"locator","at":1492525493,"ct":1492525493,"dur":86400,"fl":256,"items":[13809560],"p":"{\"note\":\"\",\"zones\":0,\"tracks\":0}"}
you need take the property h of this respense because that is you locator link
On my case concat that property with
