Testing: Additional geodata sources
(edited by Kirill Yakunin 29/03/2017 17:55:06)
Topic: Testing: Additional geodata sources
No monopoly! At least when we speak about GIS-services. In Wialon beta-version you can now choose Google, Visicom, Yandex, Mapbox, HERE, Luxena, what3words, ArcGIS (depending on the available maps) as a geodata source instead of Gurtam Maps in User Settings. The option is realized for address column in the monitoring panel, unit and track tooltips, messages panel, addresses when creating geofences and routes. Got used to a certain map layer for its accuracy and high quality? Now you have a chance to use perceptive data for the benefit of your business.
Marketing specialist, Gurtam
Re: Testing: Additional geodata sources
This would be very useful indeed.  When will this be finished in beta do you think?
jonasf_ph , it's available in Beta now. And will be set in Stable in a month
Tatsiana Shmihelskaya
Business Analyst, Gurtam
Do you have the information when this will be active for reports as well?
Dragan
Dragan, we are currently working on it, but there is no final date.
(edited by florin1 31/05/2017 22:18:22)
Hello. I can only see Google and Gurtam for geodata and Google and Openstreetmap for map source, in the Beta version.
florin1, the number of maps you see depends on launched maps to your DNS. If a map you need is not available, address your request to Gurtam Help System.
