OAuth error ?
Topic: OAuth error ?
Yesterday morning at around 10:35 am (Eastern Time), all our data acquisitions using the Wialon REST API stopped working.
It seems to be a problem with OAuth.
Calling the login method, passing one by one all the permanent tokens we had, returned the error code '4'.
I regenerated new permanent tokens for my users via this url: http://hosting.wialon.host/login.html?sv … vc_error=7
Yet, my calls to the login method of the REST API keep on failing with the error code '4'.
By the way, I did verify that application tokens do appear on the Wialon console, so that's why I think there was an update or something your side which broke the way OAuth was working.
Can you please help me to solve this ?
Our customers are no longer receiving their data since yesterday morning.
Thanks
OAuth error ?
Re: OAuth error ?
NTS, do you still have problems with invalid tokens? For more details You can provide user name and invalid token example (private message).
OAuth error ?
Re: OAuth error ?
Hi,
yes we still have a problem with the remote API.
I sent you a email about that
We're waiting for your reply.
OAuth error ?
(edited by deal 24/01/2017 11:07:43)
Re: OAuth error ?
NTS, You need to wrap token value in double quotes (because it should be a string and json parser fails). Example: {"token":"89bc9b71d4abXXXXXXXXXXXXXXXXXXXXXXXXXXXXB0BC62A7E"}
