Wialon Messages over 10,000 stops working
Тема: Wialon Messages over 10,000 stops working
Hi,
I have an web application that get the message from a one unit at time to finally create driver's path in google maps.
One user has as much as 30,000 messages.
I'm using Javascript and using the functions
var ml = sess.getMessagesLoader();
ml.loadInterval (unit_id,timeFrom,timeTo,0,0,100,callback())
inside the callback function I do
ml.getMessages(0,30000,function(code,data){
more code here
If I ask for 30,000 messages it stops working but if I go 10,000 or below it works fine.
Any help would be appreciated ?
thanks!
Re: Wialon Messages over 10,000 stops working
arrays big enough? can http requests even send so much data?
from this "http://sdk.wialon.host/wiki/en/kit/remot … its/limits" it should work...
(i beliebe its some limitations in your programmcode / http protocoll or so...)
Wolf.
(but i am sure the geniuses from Gurtam will answer soon ;-)
Hi
What do you mean "stops working"? Network request fails, javascript exception or ...?
Wialon has some limits like
No more than 4 million messages can be loaded into all user sessions
but i think you'll never face it.
Please check how many messages were loaded in loadInterval callback
Then you can add console.log(arguments) into getMessages to check what arguments come to function
Also some more info about "stops working" or piece of code will be helpfull
Alex.Villalta, do You use Wialon Hosting or Local?
wwbusch aka Buwo pointed You to docs about Hosting requests limitations.
Wialon Local limits can be customized to lower values by admin.
As for big arrays - responses of http requests can be much bigger without problems.
(Actually response data size technically can even be unlimited).
Maybe there is some problem in Your code?
Try to comment everything in getMessages callback and just print the length of recieved data:
console.log(data.length);
