Getting unit messages (pop up alerts)
Topic: Getting unit messages (pop up alerts)
I am able to get all available events from units
http://hst-api.wialon.host/wialon/ajax.html?params={'spec':[{'type':'col','data':[508203,11790037,11790040,11606835,11720764,11687531,11606782],'flags':4294967295,'mode':0}]}&svc=core/update_data_flags&sid=aa31403810a11c3135d4a022096460ff
But I am not getting any alerts messages.
What flags should be set to get all events and popup messages?
Nishad Hussain Kaippally
Re: Getting unit messages (pop up alerts)
Dear  Nishad, wialon doesn't send any alert or popup messages. After getting an answer on your request  you should analyse it, and decide is it valid or alert must be shown. The same deal we have with popups. You analyse the result of avl_events and show or don't show popup.
Development Department
I am now using the following query to get all available events from each unit
svc = core/update_data_flags
params= {'spec':[{'type':'col','data':[571714,11750160,11689962,11744875,11713311,11725919,11737849,11708287,11715669,11725999,11725855,913729,7325290,534828,11712610,11716374,11697887,11689902,11716596,11808777,11697338,11750079,11697833],'flags':4294967295,'mode':1}]}
but I am not able to get any events.
I also tried first to remove all flags
http://hst-api.wialon.host/wialon/ajax.html?params={"spec":[{"type":"type","data":"avl_unit","flags":4294967295,"mode":2}]}&svc=core/update_data_flags&sid=139e95bb4e18f1bfa591a4ca3cdf2286
and then tried setting new flags to get all events from all units
http://hst-api.wialon.host/wialon/ajax.html?params={"spec":[{"type":"type","data":"avl_unit","flags":4294967295,"mode":1}]}&svc=core/update_data_flags&sid=139e95bb4e18f1bfa591a4ca3cdf2286
but I still get no events.
Can sombody help?
Please check out our Item events management sample. I beleive it can be helpful.
BTW, what programming language do you use? Did you try Wialon SDK JS?
I am working wialon remote API
