Teltonika FM1100
Topic: Teltonika FM1100
Dear Firends
We have a problem with FM1100 Ibutton readings,sometimes it just doesnt read ibutton .
It is working normally most of the times but suddenly doesnt respond and after some time works again .
Does anyone had same problem ?
Teltonika FM1100
Re: Teltonika FM1100
just be sure you configure correctly on the configurator
Teltonika FM1100
What can be done wrongly?
Average constant =1
0
0
monitoring(or any other it doesnt matter)?
Teltonika FM1100
I have a problem with FM11XX_Configurator_v1.1.6.3  That can't config my device.
popup error "device firmware not support " How I get device firmware for use with FM11XX_Configurator_v1.1.6.3 ??
or any way to do with my device ??
Teltonika FM1100
Please read this section
Teltonika FM1100
Козлов Сергей
ООО "ГК"АТС-Мониторинг"
Регион: ПФО и не только...
http://www.atc52.ru
Teltonika FM1100
(edited by ephedrine 04/10/2012 18:17:53)
-_-''  Thank for you reply but I can't read russia!!  :-(
I try google translate That to really BAD.
Teltonika FM1100
I've sent you the latest firmware for your version of the configurator. Please check your e-mail.
Козлов Сергей
http://www.atc52.ru
Teltonika FM1100
I need to have a temperature sensor that is compatible with Teltonika FM1100. Any ideas ?
Teltonika FM1100
Read manual?
Page 15:
1 – Wire devices
One of the realized features FM1100 is 1-Wire® dataprotocol, which enables
connection of thermometer (DS1820, DS18S20 and DS18B20)....
Киев, Черкассы, Винница.
http://overseer.ua
Teltonika FM1100
Hi dear Gurtam Partners,
did not want to write into the public area so here is a urgend problem we have with the FM11 devices:
We have mounted a Buzzer to DOUT2 and need the Firmware "29.01.01" which enables EVERY IBUTTON connected to the FM11 to have 0.5 Seconds DOUT1=1. (Buzzer will Peep for 0.5 Seconds).
Does anybody have this Firmware?
Or does anybody has a firmware which i can use for this?
Thanks
Wolf.
(wwbusch@gmail.com)
Teltonika FM1100
Hi,
We have small problem configuration with the FM1100 .... and the I-Button
We configured the I button ...it works ...BUT it doesn't keep the settings ..as soon as we remove the button it send a ""zero""
I think we made a wrong setting ..
Who has a solution for us smile thanks in advanced
regards
""Baltika""
Teltonika FM1100
Hello,
No wrong settings, it is FM1100 feature ;-)
At the settings you should set Reverse iButton and Deny empty iButton registration functions.
(because of these there won't be lines with empty ID=' ', so the driver stay logged in (binded) even there was only one iButton code when the iButton key was connected to the reader.
For unbinding you should make a Notification like this:
Digital input activation/deactivation > chose ignition's digital input & check for deactivation > Reset driver
With this method driver will be unbinded when the ignition is turned off.
Regards,
Krisztián
Eflotta Vehicle Tracking Ltd, Hungary
www.eflotta.com
Teltonika FM1100
Hi Krisztián,
Thanks ...we will try smile I will keep you posted ..
regards
Baltika
Eflotta wrote:
Hello,
Regards,
Krisztián
Teltonika FM1100
I have discuss with  teltonika sell officer and he said
" basic FM1100 firmware does not have GPRS commands, you need a special firmware for that, goods can be acquired with it. What is the firmware version of units you have? I will check what kind of firmware it is and whether it supports GPRS commands. Each firmware has to have a matching configurator."
I want to know any one have gprs enable firmware and match configurator .  I just want to test  my device on my platform.
Ps. firmware version is version 12.xx.xx
Teltonika FM1100
i dont think they have a fw they do the hardware/software configuration for some reason that is one of there flaws
Teltonika FM1100
But I used a lot of teltonika from different supplier . Each supplier have they own firmware for those device.
I have some device come with online platform support and those device can recieve gprs command to cut engine / remote management .  firmware is version 12.xx.xx But I can't config device with other configulator . when I flash device with other firmware (1.xx.xx )  device not respond to command .
Teltonika FM1100
If you are using a standard FM1100 it will accept GPRS based commands, you do not need any special changes. In Wialon you just need to mak sure that you set up commands for the units.
The command can only be sent if the unit has an active GPRS session.
I am having a firmware modification done to have 150 geozones stored on the device so we can set up a route and route management using only sms and to both the monitoring application and a mobile phone.
The current firmware version is FM11010720.e and the configurator is 1.1.7.15. This also has a fix for a GPS bug.
Regards
John
Phoenix Solusi
Mobile Visible Secure
Teltonika FM1100
(edited by ephedrine 26/04/2013 05:55:18)
I didn't use Fm1100 with wialon . I have my own platform .
And I want to send output activate command via gprs.
I try device with fw1.xx.xx is not work . but device with Fw 12.00.00 is work(I not have fw & match configulator) .
Teltonika FM1100
Teltonika FM1100
Just sent you the latest files to your email. Try these.
Phoenix Solusi
Teltonika FM1100
Thank you , very much
Teltonika FM1100
Let me know if it works
Phoenix Solusi
Teltonika FM1100
I didn't receive any email . what e-mail address you're send ?
please send to : info@smarttrack.in.th or use file hosting . I use gmail service it's block some file content .
Teltonika FM1100
Guys,
Could you add me some examples about the sintax to send gprs commands?, I use a Teltonika FM5300 and I don't know if I have to put login/password, or APN Name/APN Pass for Gprs particular case. that's will be helpfull.
Jorge Baeza Osorio
Teltonika FM1100
Hi Jorge,
Are you trying to send the commands from within Wialon?
Regards
John
Phoenix Solusi
Teltonika FM1100
Hi Krisztián,
Is there a way to ""retranslate"" the reverse code what is send to Wialon into the code ""on the key"" ? ( retranslate by hand or tool )
regards
Baltika
Teltonika FM1100
Unfortunately no, or we don't have such a tool. We copy these codes from the messages.
Regards,
Krisztián
www.eflotta.com
Teltonika FM1100
hi,
Here is the answer:
Q: We have our server and we are testing iButton, ID on iButton is 79000015BFD23001, but on server we see other value 85800111052947580, how to convert it?
A: iButton ID is devided in 8 bytes and bytes are sent starting from 1st to 8th:
ID on iButton:
79000015BFD23001 <--
79 00 00 15 BF D2 30 01
Readed value:
01 30 D2 BF 15 00 00 79
This is the answer from the Teltonika guy's
regards
Baltika
Teltonika FM1100
Hi Kristian,
Can you show me a screen of that ""reverse"" setting ?  for some reason we dont have this in our software (ver 01.07.33)
thanks and regards
Baltika
Eflotta wrote:
Hello,
Regards,
Krisztián
Teltonika FM1100
Hi, Baltika
The option "Reverse ibutton" is set on the unit properties near the device type (additional button)
On the right of the entry field there is a button which can be used to configure device parameters for the given unit:
http://docs.gurtam.com/en/hosting/cms/units/general
If in your Wilaon Pro this option doesn't exist please write to support@gurtam.com we send your a updated scipts. (for Wilaon Pro 1106 )
Teltonika FM1100
Hello to all.
I'm new in using Teltonika FM1100, but I am not new in GPS tracking. I got one unit for testing, I got a manual, I downloaded the configurator, terminal, and MServer. The first problem is to force the unit to join to the server. In the configurator, in the section GSM I set the IP address and port of the server, login APN etc.... As a server I have used their MServer, but I build and own a simple listener. The result is that the unit not register whatsoever. If I set the unit from another manufacturer on this same server, so they communicate.  Can you tell me where is the problem?
P.S. I tried to send an SMS command flush. In this case, the unit sends a record to the server.
Thanks
Teltonika FM1100
Hi Guys,
just want to let you know, that T made a working "Private Mode" Function for us in FM11.
For those guys who has problems with their datasecurity officers...
So now "employee" can connect switch on DIN2 and if DIN2=1, device will not SAVE and SEND any data. If DIN2=0 device works absolutely like normal.
So if you need this function please ask your local sales guy from T.
Wolf.
Teltonika FM1100
How does this work? is it a firmware update for the FM1100?
Thanks
Teltonika FM1100
(edited by wwbusch aka Buwo 06/12/2013 18:11:56)
Hi Chris,
yes its a firmware made for us (and costed a lot :-)... you need to ask your local dealer for it :-)
by the way, Ruptela wrote me, that this function is already implemented in their standard firmware which is for free. (just to be fair)
Wolf.
Edit: ups, i did not ask your full question... if DIN2=1, no data is saved / collected / send, if DIN2=0, standard functionality.
(i think they did in sourcecode something like
WHILE new_data_to_be_collected_function
   IF DIN2=1 do nothing
   ELSE do what you do normaly
END WHILE
so 750.-€ per line of source code payed :-))
Teltonika FM1100
Делал ли кто-нибудь посредством данного прибора управление через реле? Подключаем, отправляем команду, управление выходом не срабатывает, но при прозвонке на массу значение тестера с 1(нет проводимости) меняется на 670 (непонятно что)... Заранее спасибо за помощь
Teltonika FM1100
Делал неоднократно это делали. У вас просто видимо не срабатывает из-за не правильной команды или еще чего-то
Teltonika FM1100
Hi,
I have Teltonika FM1100 and FM5300 and I'd like to send remote commands through Gprs using Tcp/ip instead of costly (and lengthy) sms.
I have an outgoing Tcp/Ip connection established with a device that is sending its position to the server every minute, but sending commands formatted according to the manual has no effect whatsoever.
For example:
Sms command getstatus or any other sms command has no effect and no response is received.
Gprs command #GET VERSION or any other gprs command has no effect and no response is received.
setparam 1245 127.0.0.1 or any other gprs command has no effect and the server address field is not changed if a check with Teltonika software configurator.
Any help is appreciated.
Teltonika FM1100
Hi .
As principal you need to hold TCP connection to enable sending TCP commands.
Look for hold coonection in the Teltonika setup. define heartbeat to 5  minuts.
Hope it will help.
I know it from other Teltonika models.
koby.
Koby Karat
Ananas Global
Teltonika FM1100
Like title says, can someone tell what is the revision number of the latest Teltonika FM1100 firmware ?
Thank You
Teltonika FM1100
Last one I have is FM11010720.e
Phoenix Solusi
Teltonika FM1100
Did you get the GPRS comands working?
Phoenix Solusi
Teltonika FM1100
Hi Guys,
i am also since 3 hours here trying to get it working.
i always get #ERROR message.
John, hope you did not forgett username/password?
i testet with (sample) "hill 12345 getversion"
So maybe Gurtam Support can tell us something about how a custom command need to look like?
Wolf.
Teltonika FM1100
No Buwo....misplaced it for a while :-)
Phoenix Solusi
Teltonika FM1100
i got today the info from teltonika sales guy (hi Stanislavas ;-) that the new firmware versions does not support any gprs remote configuration by other plattforms then their own plattform. So if you buy new Teltonika HW you should beware of this!
(and i cancel my plans to do my "automatic private mode" via commands and wait that "The Geniuses" (tm) will implement it in Wiaon.
Wolf aka Buwo
Teltonika FM1100
01.07.40 is latest i have.
Wolf.
Teltonika FM1100
Wolf is there a new configurator for your version?
Phoenix Solusi
Teltonika FM1100
(edited by JohnG 13/04/2014 15:35:33)
Wolf I checked with our Teltonika contact and what you were told is not correct.There has been no change in Teltonika devices being updated by other platforms from a configuration point of view. They have made some changes that have additional functionality available on their platform but none of this affects configuration.
Phoenix Solusi
Teltonika FM1100
Вышлете пожалуйста последний конфигуратор и прошивку на 1100   shizko@mail.ru
Teltonika FM1100
I have a very big problem with my FM1100. I used flush SMS command  to make it send data to a target server. But connexion to server is still not available. What did I do wrong?
Teltonika FM1100
Hi , MaryTudor
When you send sms command to config your fm1100 . It's reply all parameter is change ?
if anything is done . may be you need to config network operator code .
Teltonika FM1100
ephedrine wrote:
Hi , MaryTudor
Well, it sends back a text message saying that parameters are accepted. where can I find my operator code?
Teltonika FM1100
Well , I am able to get gps data via SMS. My problem is how to get GPRS connexion to make the device send data to the server.
Teltonika FM1100
Hi Guys,
just for you to know:
1.) there is an firmware for fm11 which supports gprs commands. Ask your Teltonika guy for that firmware.
2.) FM5300 needs to be used with "custom commands". Just use all commands you find in manual. You dont need to write username/password into the command as they are not necessary in gprs commands.
3.) reply of units are shown as Drivermessage in wialon.
enjoy
Wolf
Teltonika FM1100
Да, мне тоже интересно, как слать команды на телтонику из виалона. Если будет тема по-русски, расскажите, ребята)
вы тут немного подварите, а я дома проволокой намертво примотаю
+79634551777
Teltonika FM1100
hi guys,
we want to SET the "flash-password" of FM11 via SMS and dont know if this is possible?
We already set the username and password to all of our devices but that can be reset by just flashing it. There is an additional password which you need to set if you want to connect it to the configuration software, but i dont know if we can set it just by SMS?
Help would be appreciated!
Thanks
Wolf
Teltonika FM1100
Hello Wolf.
We have no such information. But if we get it we will inform you.
Teltonika FM1100
Configuring Teltonika FM1100, FM4100, FM4200, FM5300 devices via TCP/IP is now available in Wialon.
The process of configuring via TCP includes the following stages:
1) the server (Wialon) sends a binary SMS to the device.
2) the device connects to the server (Wialon) to receive configuration.
3) the server (Wialon) sends configuration to the device.
4) the device breaks the connection.
User must create SMS command Upload configuration (upload_cfg) in Wialon and upload a configuration file while creating or sending the command.
Configuration file must have a certain format described in the Instruction on configuring via TCP the link to which is placed on FM1100 page on www.gurtam.com:
http://gurtam.com/en/gps_tracking/gps_h … ?id=216940
The Instruction:
http://extapi.wialon.host/hw/cfg/teltoni … tcp_en.pdf
Teltonika FM1100
Registration of parameters for LBS Detector (getting position on the basis of GSM parameters) has been added for Teltonika FM1100, FM1200, FM5300
Teltonika FM1100
I have a problem in configuring 1 wire temperature sensor and can somebody help me to know how to add temp sensor, what parameter to choose and how to set the calculation table wizard. The temperature graph to be set should be in the range of 40 degree celsius to -40 degree celsius.
Regards
Abraham
Teltonika FM1100
https://www.youtube.com/watch?v=En4m1IF3RaQ
Teltonika FM1100
Hi,
it is ""param72''  for the FM1100
Calibration table settings:
X  <>  Y
-1000  <> -100
1000 <> 100
It means value divided by 10
Goodluck
Teltonika FM1100
Thank you very much friends.
The system is working fine now.
Teltonika FM1100
I am new in using Teltonika fm1100.i want to monitor fuel and have done tank calibration by getting the changes in voltage due to to changes in fuel levels.i dont plan to use a fuel sensor.In the fm configurator,how can i choose the parameter that wil have me see the fuel in the tank.i have done the calculation tables.kindly assist
James
Teltonika FM1100
james,
use analog input of fm11.
wolf
p.s. connecting additional hw to tank voltage display may result in wrong display of display !
Teltonika FM1100
Hi James,
The parameter is : adc
We also have ""special"" hardware to avoid also the problems with the analog fuel meter, with this you can also detect Fuel Theft etc .
http://www.tracesolutions.eu/fuel-senso … apter.html
regards
Teltonika FM1100
Hello guys,
I have a client in Colombia with issues with the Panic Button (SOS)  on his Teltonika FM1100 devices:
The frequency of messages is every three minutes. When he presses the panic button nothing happens and no new message comes in, but a panic message will come inside the normal message every three minutes.
Me point is, regardless of the Panic Button being pressed or not, the device ALWAYS reports every three minutes. Could you help with the correct configuration in order for the device to send a new message every time the panic button is pressed?
I know the Teltonika FM1100 is very popular, so I was wondering if someone could tell me what would be the best configuration to get everything working nicely on Wialon.
Thanks for the help.
Teltonika FM1100
Hi,
I have a FM5300 on which I try to send gprs commands. I saw in the manual some example commands and was able to reconstruct:
- the first 8 bytes are message length;
- some unknown (but maybe constant) bytes
- then the message as a byte array
- then some extra unknown bytes.
Could anyone detail what the unknown bytes represent and what's the format of the gprs command on 5300 supposed to be?
setdigout 1000 10 0 0 0
$00$00$00$00$00$00$00$21$0C$01$05$00$00$00$19$73$65$74$64$69$67$6f$75$74$20$31$30$30$30$20$31$30$20$30$20$30$20$30$0d$0a$01$00$00$e5$ca
#SET OUT=1,0,0,0
$00$00$00$00$00$00$00$1a$0C$01$05$00$00$00$12$23$53$45$54$20$4f$55$54$3d$31$2c$30$2c$30$2c$30$0d$0a$01$00$00$fd$34
#SET OUT=2,1,0,0
$00$00$00$00$00$00$00$1a$0C$01$05$00$00$00$12$23$53$45$54$20$4f$55$54$3d$32$2c$31$2c$30$2c$30$0d$0a$01$00$00$3e$05
#SET OUT=1,1,0,0 15,30,0,0
$00$00$00$00$00$00$00$24$0C$01$05$00$00$00$1c$23$53$45$54$20$4f$55$54$3d$31$2c$31$2c$30$2c$30$20$31$35$2c$33$30$2c$30$2c$30$0d$0a$01$00$00$83$c6
wwbusch aka Buwo wrote:
Hi Guys,
enjoy
Wolf
Teltonika FM1100
Ricardo Sandor wrote:
Hello guys,
Ricardo,
why not asking me ;-)
you need to set priority in IO setting on Input(x) (where you connect the sos button) to high and set it to send on each change a message.
(basicaly the same setting for the input as you need to set it for ignition to get always ignition on/off )
If you have still problem give your customer my skype and we do a remote session.
Wolf.
Teltonika FM1100
aspacardin wrote:
Hi,
#SET OUT=1,0,0,0
#SET OUT=2,1,0,0
Hi Guys,
enjoy
Wolf
Aspacardin,
what are you trying? Debugging TCP/IP messages or using commands with Wialon?
for first ask Teltonika, for second: Just use commands as i described it, that works fine for FM11 and FM53!
No need to use any kind of "byte/hex" messages
Wolf.
Teltonika FM1100
Thanks for your reply! I need to integrate it with a separate service, so I need to find the commands and it's very hard to get an answer from Teltonika. It's very important for my work and it's frustrating that I'm only missing a few bytes. If you happen to have the protocol, please send it to aspacardin4@gmail.com, it'll help me a lot!
aspacardin wrote:
Hi,
#SET OUT=1,0,0,0
#SET OUT=2,1,0,0
Hi Guys,
enjoy
Wolf
Aspacardin,
Wolf.
Teltonika FM1100
Hi,
sorry, we signed (as all Teltonika Partners) an NDA.
So no way to get the protocol description!.
And come on, you are here in the Forum of Gurtam = manufactor of Wialon. Why they should help you implementing hardware into a competitor software? I would not do that! Never!
Wolf.
Teltonika FM1100
wwbusch aka Buwo
Hello Wolf,
Like always thanks for the help. I'll be contacting you shortly.
Ricardo.
Teltonika FM1100
Hi Everyone,
I'm Xavier, a french newbee working with Wialon since few months.
Well, we need to connect FM1202 and FM 1100 (2 differents needed) with a Block and Unblock engine command from Wialon to the device.
At this time, we have good results with the block engine, as well with the 1100 and the 1202, but we can't Unblock devices when sending the Unblock command.
I'm not sure that is a typical device's issue, but a wrong prg of the commend sent by ourselves;
If anyone of you may help us, it should be greatly appreciated.
Thank You,
Greetings from the south of France
Teltonika FM1100
Hi ""Greetings from the south of France""
Send me a PM and I will send the details ( drawing etc )
regards
Baltika
Teltonika FM1100
I want to configure FM 1100 for a in lab project. When I connect it with my laptop for configuration, i get the error message for using some kind of configurator which I could not find so far.  Can someone guide me please? I have attached the screenshot of the error message.
  • Teltonika FM1100
75
Teltonika FM1100
Hi,
Read the txt carefully on the picture !! You only need a new configurator. Contact your supplier of the Teltonika units
regards
Baltika
76
Teltonika FM1100
Hi Baltika
Thank u for ur guidance. However, have not been able to reach the correct person to get the right configrator.
Can some help me find it on the internet some where? OR it is a compulsion to get it from where I bought the device?
77
Teltonika FM1100
(edited by Baltika 18/03/2015 11:30:30)
Hi pervaizbutt,
You will not find on internet, give me a PM or Skype   and I will handover to you
My Skype: hsrutgers
regards
""Baltika""
78
Teltonika FM1100
if you know your Firmware version , I can send it to you. Or try to find the firmware updater in your zip file.
Regards
EQ
79
Teltonika FM1100
Hi,
I don''t need, I have all ..
thks
Regards
Baltika
80
Teltonika FM1100
i think it would be much more easier just to flash latest FW and than use the correct configurator ;-)
But harms, the x.8.x firmware, what special functions does it has?
Wolf.
81
Teltonika FM1100
Hi Wolf,
We have the best experience with the 10 version ...  we use this for the FM11xx series ..
It  solves the GPS problems as you can have with the other/older versions.
regards
Baltika
82
Teltonika FM1100
Hi Harm,
yes, we also use it and its perfect.
missed you at the cebit!
Wolf.
83
Teltonika FM1100
Can somebody help me in configuring FM1100 output, Am using Output 1 for engine cut off
Need instruction for hardware configuration and setting commands in wialon
84
Teltonika FM1100
Hi Orosgroup,
Contact me in Skype: hsrutgers  (txt-chat)
I have all instructions<>drawings on my hand
regards
Baltika
85
Teltonika FM1100
by the way, as i remember not every firmware supports tcpip bases commands on fm11!
Wolf.
86
Teltonika FM1100
Hi Wolf,
True !! smile
regards
Baltika
87
Teltonika FM1100
Hi guys,
after becoming a customer of swedish TELE2 M2M unit i am wondering how to configure the FMxx series from Teltonika in a correct way...
If i want to use it in germany, country code is 262 and networks 01,02,03,07. But Homenetwork is Sweden?
So what would i configure ?
Thanks for Ideas
Wolf
88
Teltonika FM1100
Wolf, I have one idea - you can get in contact with our partner in Sweden (the guy I wanted you to meet at CeBIT but you were at our booth at different days). Just ping me on Skype and I will send you his contact info to see if Dean will be able to help.
89
Teltonika FM1100
(edited by kvdm 10/04/2015 16:01:10)
Hi guys,
Thanks for Ideas
Wolf
If you use a sim card of a Swedish operator you must indicate this very same operator network number.
If you use a sim card of a German operator you must indicate this very same operator network number.
I.e. you must indicate the number of the network of the gsm provider that you use.
90
Teltonika FM1100
Hello,
could someone please send me working firmware for FM1100? Recently we are having problems with GPS connection lost. Communication with Sales representatives from Teltonika company is too difficult and they always send us firmware with errors.
Thank you
91
Teltonika FM1100
Hi mimicar smile
haha  YEP !!! Contact me on Skype pls : hsrutgers
regards
Baltika
92
Teltonika FM1100
Hi , I'm sending commands ( set param 1245  *adresseip* )within GPRS The device send me "ping" as result.
Can anyone help me to fix the problem.
93
Teltonika FM1100
did you try to send other commands? does that work?
not all fm11 fimware is able to receive commands via gprs!
The command you wrote is ok and should work.
Wolf.
94
Teltonika FM1100
Hi
Greetings from TZ.kindly can you send me a configurator for teltonica fm 1202
95
Teltonika FM1100
Hi,
http://avl1.teltonika.lt/downloads/
BTW: you can also ask your suplier smile
gr Baltika
96
Teltonika FM1100
(edited by applevamsi 04/05/2015 19:50:22)
Hi,
We have purchased Teltonika FM 1120 and connected temperature sensor DS18B20 by taking middle pin as an input to the device and not given any external power to DS18B20 (Parasitic mode).Am not receiving any data from the device to the platform and I have selected "param72" in the sensor setting.Any advice guyyss
97
Teltonika FM1100
You must connect two other pins to GROUND, not to leave it open.
Сергей Чубаров.
Директор ООО "Ратеос".
www.rateos.ru   rateos@rateos.ru
+7 (499) 731-4390, 731-9716
98
Teltonika FM1100
Hi
I need firmware for Teltonika FM4200 that supports garmin .
please send me at marouen.baklouti@gmail.com
Please help and thank you in advance for you replies and effort.
99
Teltonika FM1100
Hello,
I would like to ask you concerning problem with GPS connection of FM1100. Recently offen happen that some of FM1100 suddenly lost GPS connection and then after some time the connection is back ON. For example: Tracker have locked 17 satellites and work OK, car is driving on highway and suddenly the number of satellites is 0. We already tried to change the firmware (thanks to "Baltika" smile ), but the problem still remain. We have this problem with trackers bought after December 2014. Does anyone have similar problem with trackers Teltonika FM1100?
Thank you for any answer or help.
Michal
100
Teltonika FM1100
Hi Michal,
Contact me on Skype pls ( hsrutgers )
regards
Baltika
101
Teltonika FM1100
Hi,
Do you still need this FirmWare for the FM42xx ?   I have it for you ..
Skype me pls: hsrutgers
regards
Baltika
102
Teltonika FM1100
Hi,
No, thanks a lot.
Best regards.
103
Teltonika FM1100
reason is a faulty gps antenna shipment in january 2015. try to exchange gps antenna, than it will work again...
104
Teltonika FM1100
(edited by tonnorlando 03/06/2015 23:00:24)
Buenas
Hace un mes que venia con este mismo problema, en 8 equipos fm1100, comprado en febrero.
De a poco se corta la señal gps, y 0 satelites.
La solucion la encontre hace 4 dias, actualice el Firmware con la ultima versión que me ha
pasado Teltonika, y en los 3 fm1100 que actualice, se ha solucionado. Funciona normal
Firmware updater 1.10.17
105
Teltonika FM1100
Hello Wolf,
up today we replaced 5 GPS antennas and everything show that they were defective. Do you have any detailed info what was wrong with them?
Did you have similar problem? Did you open complain on GPS antennas to Teltonika?
Thanx.
106
Teltonika FM1100
Hello Tonnorladno,
on all FM1100 that show lost of GPS satellite connections we have firmware Ver:01.10.17 Rev:6. Even on FM1100 that are in vehicles connected to CAN BUS we installed firmware Code Ver:43.02.01. Unfortunatelly this problem was solved only after replacement of GPS antennas.
107
Teltonika FM1100
Some Times the antenna is not connected properly and it moves slightly from the main board of the device when the device are open for inserting sim or connect backup battery
Please check that too hope it helps mimicar
Regards
Yoosouf Parvez
From Startouch
Mobile : +23057631200
108
Teltonika FM1100
well, when i have read this thread and heard from Baltika that he also heard about this from some of his customers i just mailed our Teltonika sales Guy and asked him :-) Simple or?
I have no idea what was wrong but typicaly its some problem of cable/soldering etc...
Wolf.
109
Teltonika FM1100
Please don't blame Teltonika .
Just blam yourself for using Teltonika.
My experience.
Koby Karat
Ananas Global
110
Teltonika FM1100
Hi dear colleagues around the world,
Teltonika offers me to work with the new generation of FM 11XX (1110 & 1120).
Can you confirm me that the protocols and Port (20412) are the same we used already with the FM 1100 to connect to Wialon ?
Thank you guys,
Xavier
111
Teltonika FM1100
Xavier
yes, keep using 20412
Business Development Manager
Teltonika FM1100
Thank You wink
113
Teltonika FM1100
Buenas tardes, estoy intentando usar la salida 1 de un fm1100 pero no logro activarlo a través de wialon, comando tcp. alguien podría ayudarme con esto?
114
Teltonika FM1100
(edited by tonnorlando 03/07/2015 20:41:48)
Buenos días,
Estoy utilizando  el out 1, para el corte de motor y no logro activar o desactivar a través de la plataforma; solo me funciona a través de sms enviados por teléfono. Como hago para activar o desactivas desde la plataforma??
Gracias
115
Teltonika FM1100
(edited by milleniumpower 05/07/2015 08:23:24)
Hi everyboy
Actually am using Teltonika FM1120
I wanted help on, how to collect the drivers behavior data from the device in message ( wialon)
How to differentiate between the following  :
Harsh Braking
Harsh Acceleration
Sharp Turn
Sudden lane Change
and whatever else the device can provide
Please let me know in which Param to collect the data and how to split the data in sensors for later built the Eco driving rules
Awaiting your help thanks
Regards
Yoosouf Parvez
From Startouch
116
Teltonika FM1100
Also i dont understand any word of your text :-) i will try to answer you:
easiest way:
1.)deactivate sleep mode in FM11 and let the device send all 4 minutes a "hello here i am" message to Wialon.
2.) create 2 commands via TCP! with "setdigout 00" for deactivate DOUT1 and "setdigout 10" for activating DOUT1
3.) dont forget that DOUT1 is a open collector output = you dont have PLUS voltage at the output BUT GROUND if DOIUT=1, so you need to use a relais!!!
By the way, maybe you need latest firmware for the FM11... older Firmware does not support GPRS commands.
117
Teltonika FM1100
milleniumpower, with param253 (each non-zero value represent special event occured) you can create at least 3 sensors by using appropriate calculation table: harsh braking, harsh, acceleration and sharp turn.
Please let me know if you need further guidance.
118
Teltonika FM1100
Orlando is wondering about out 1 for Teltonika fm1100, for blocking the engine. The command is sent only via sms from the telephone, and is not sent from the platform.
119
Teltonika FM1100
tonnorlando, Make sure you have SMS package activated and you have SMS available. You can check it in CMS Manager. If you steel have doubts, feel free to write to support@gurtam.com
Tonnorlando, Asegúrese de que tiene el paquete SMS activado y tiene mensajes SMS disponibles. Esto se puede ver en CMS Manager. Si tiene más preguntas, siempre puede escribir a support@gurtam.com
120
Teltonika FM1100
milleniumpower, ok, did you activated eco-driving features in Features/Scenarios/Green Driving section of configurator. Are you seeing param253 in messages?
If this is light vehicle you can start with 0.3g for acceleration and 0.4g for braking.
121
Teltonika FM1100
And then, import attached .wlp configurations of sensors + eco-driving block into desired unit and test.
p.s.
Thanks Wolf for provided original file with calculation tables.
122
Teltonika FM1100
i Have uploaded it the wlp on the unit
will try tomorrow a let you know
thanks
Regards
Yoosouf Parvez
From Startouch
123
Teltonika FM1100
Hello again friends,
Since I cannot find any info on this, could someone explain the process or upload a manual, if one exists.
How would I make this work with FM1100? Any settings required in the configurator?
Cheers
124
Teltonika FM1100
Hi n.sehictz,
Did you try to ask Teltonika ?
regards
Baltika
125
Teltonika FM1100
Yes I did, but I have a feeling it will go faster here smile
126
Teltonika FM1100
Hi,
I doubt .......... because if you buy FM1100 and LV200 you also can ask for the manual...    Or did you buy at corner of street on a dark rainy evening ?
regards
Attachment icon FM1100 with Light Vehicles Can adapter LV-CAN200 v1.1 (1).pdf 543.74 kb, 1678 downloads since 2015-07-28
127
Teltonika FM1100
Imperium, te paso un enlace que contiene Manual, y algunas informaciones mas, ahi la puedes descargar  https://drive.google.com/open?id=0BwkND … TZzNjh5eVk
128
Teltonika FM1100
@Baltika, thank you for URL. I asked for manual, they ask "what vehicle will you be putting it in", so it's an unnecessary procedure. I know they need that info for specific connection scheme but I require the general manual, to understand the workings better.
And since there's no manual on avl1.teltonika.lt/downloads, I thought I'd ask here. @tonnorlando thank you as well.
129
Teltonika FM1100
Hello guys. I just got a teltonika fm1100 and i am struggling to configure it via usb cable.
For the usb config i downloaded some configurator tools from their website but i get this error:
"Configurator version does not correspond to FM firmware version. Software version like X.1.11.Y should be used to configure your device".
Ok so i understand that i need a certain version of the config tool. My device has Code ver: 01.11.07 and i cannot find anywhere this configurator version.
Does anybody else had this problem and has the recommended config tool?
Thanks!
130
Teltonika FM1100
Hi florin.stana,
This not a problem, just ask your supplier of your FM11xx unit ..
regards
Baltika
131
Teltonika FM1100
good luck with CANBUS reading :-)
We are still learning and trying since 3 years.
Without asking each time for each vehicle how to connect the correct canbus-wires (comfort can, motor can, dashbord can) you will not enjoy it!
Wolf.
132
Teltonika FM1100
did you get the problem solved?
Phoenix Solusi
133
Teltonika FM1100
Hello everybody
I have a problem with Teltonika FM1100 configurator, it´s telling me that my firmware is not the right version.
But when I try to get the firmware file from Teltonika, they just keep directing me to the sales manager for my region,
which is not really interested in sending me the firmware file.
Does anybody have any idea on how can I upgrade my device firmware or where could I get the file?
134
Teltonika FM1100
Hi,
Ofcourse we have an idea how to upgrade the Firmware and where to get the file ..
Send me a PM
regards
Baltika
135
Teltonika FM1100
Did you solve the firmware issue?
Phoenix Solusi
136
Teltonika FM1100
Hello guys.
Does the gurtam platform support teltonika fm1000 obd2 device?
I can't find it in the avl page. This device also supports commands for reading/clearing fault codes (both sms and gprs). I am also interested if i can add a custom command in the unit properties for this.
137
Teltonika FM1100
Hi,
Protokol was the same as fm1100, so you can choose fm1100.
the implementation of fm1100 supports also sending of commands, its very good implemented.
Wolf.
138
Teltonika FM1100
Thank you, so i can also view in gurtam trouble codes from the engine right?
139
Teltonika FM1100
its send as list of parameters, you need to check the DOKU which parameter means what TDC
Wolf.
140
Teltonika FM1100
Hello guys.
I have a couple of cars with Teltonika FM1100 installed and connected to Gurtam Platform.
The problem is that in the reports, there is a big difference between the reported mileage and the car's dashboard mileage. I know that they will never be the same, but it seems with each day passing the difference grows.
I have setup the following methods for calculating mileage:
For each device i have setup one Relative Odometer Sensor with parameter: param199/const1000
and one mileage sensor with parameter: odometer/const1000.
For each unit i have selected Relative Odometer for the Mileage Counter and inputed the mileage from the car's dashboard and checked the Auto checkbox.
Also i have setup a Mileage Counter Job for these cars that runs every minute with the settings found in the attached image.
Please if you know any other setup so that the data can be more accurate, let me know.
Thanks!
141
Teltonika FM1100
Hi florin1
Can you please send us an access to that unit to support@gurtam.com?
142
Teltonika FM1100
You've got mail smile
143
Teltonika FM1100
Yes, we've got it. Can you also show us the "attached image" you talked about?
Technical Support Department
144
Teltonika FM1100
with correct configuration we have less than 0,3% difference between fm1100 with odometer and real vehicle odometer.
Wolf.
145
Teltonika FM1100
(edited by fay 20/01/2016 08:00:03)
Hi,
for TELTONIKA FM 1100 with available configurator always show the message "Configurator version does not correspond to FM Firmware version. Software version like X.8.5.Y should be used to configure your device"   I need supported configurator version or standard firmware and configurator
for Help Thanks a lot in advance My email is: lineofaction11@gmail.com
with Regards,
Ch.Gul
146
Teltonika FM1100
Hi,
Maybe contact Teltonika ?
regards
147
Teltonika FM1100
Baltika wrote:
Hi,
regards
Sir, Thanks for reply
Device is purchased from third person   no  information about reseller and any other who help me this is why  I am here and again request for kind help
Regards,
Ch.Gul
148
Teltonika FM1100
Hi Fay,
ask your Gurtam Sales Person for contact details from me, if you are a Gurtam partner/customer, i will help you with that.
Wolf.
149
Teltonika FM1100
Hi Fay,
Wolf.
Thanks for reply
Ch.Gul
150
Teltonika FM1100
Hi,
We often see a difference in mileage in cars who use other type of tyres than advised according the ""book"". Also tyre pressure can make a difference!
For example: one customer had a ""tuned"" VW Golf GTI, with special "'rubber shoes"" and we noticed difference from about 10 > 15 % !!!! .
Easy test: Take a GPS navigator, program a ride of exactly 100KM, drive this and check the difference between Odometer, Wialon, and navigator .
Problem is also that customers see the Odometer as reference, these values are ""true ""  in their point of view sad
regards
Baltika
151
Teltonika FM1100
Hi Harm,
thats how we do Odometer testing :-) We have a trip on autobahn which is exact 100km with really very low number of curves.
works perfect to check which odometer is the right one...
(on my Skoda Octavia with standard tyres its less then 1% wrong)
Wolf.
152
Teltonika FM1100
Hi Wolf,
Test with my VW Passat 2.0 TDi :
  • From June 9 2010 till March 27 2011
    Used tyres: Summer and winter tyres
    Driven distance 28327 Kilometers
    At end of test Odometer in car : 127057
    At end of test in Wialon             : 126893
    Difference: 164 km this is : 0,578952942 %  !!
I used original tyres, advised tyre pressure, etc ...all according ""the book""
Note : the PDF is written in Dutch language
Attachment icon GPS kilometers versus Kilometer teller.pdf 236.51 kb, 753 downloads since 2016-01-25
153
Teltonika FM1100
Dear All
I'm having some issues with the FM1120. We have been testing 2 devices and both exhibit the same issue. Regularly (a couple of times a day) the device will stop reporting the position of the vehicle while it is moving. This can last up to 40 minutes. At some point it sends all the position reports that were not received during that period. GSM coverage is not a problem as both devices remain in the city and I know there is no issue on that side. Furthermore, we've not had similar problems with other brands of trackers.
FW version is: 1.1.0.12
Has anyone had the same problem? Were you able to fix it?
Thanks
154
Teltonika FM1100
I have teltonika FM100 device but i forgot the password i set on the device, now i have to change APN but i can not access device as it requires password, how can i solve this?
155
Teltonika FM1100
Only Teltonika can provide you with a reset key.
There is no other way.
Wolf.
156
Teltonika FM1100
Hello
Please can anyone help me to reset code of teltonika Fm100 .
157
Teltonika FM1100
Anyone has a protocol description for this device?
Thanks in advance
158
Teltonika FM1100
aahero communication protocol is commercial secret of manufacturers.
Please describe more detailed what information do you need. We'll try to help you.
Thanks.
159
Teltonika FM1100
Thanks.
I just need parameter description ,which param is what
„Engine coolant temperature“  5
„Engine RPM“  6
„Throttle position“ 7
„Vehicle speed“ 8
„Fuel level“  9
„Number of DTC“  90
„Calculated engine load value“  91?
160
Teltonika FM1100
I/O  parameters of Teltonika number "N"  are transmited like Param "N" in Wialon
Some numbers of parameters are renamed in Wialon.
Unfortunately Teltonika sometimes changes numbers of I/O that's why names in Wialon can indicate wrong parameters. We'll try to fix it later.
Please see description of your parameters:
„Engine coolant temperature“  = Param5 in Wialon
„Engine RPM“  6   = Param6 in Wialon
„Throttle position“ 7 = Param7 in Wialon
„Vehicle speed“ 8 = Param8 in Wialon
„Fuel level“  9 =   (ADC1 in Wialon) -- Because I/O №9 was reserveв for ADC1 for other Teltonika devices .
„Number of DTC“  Param 90 in Wialon
„Calculated engine load value“  91 = Param91 in Wialon
161
Teltonika FM1100
Fuel level is not shown on server side as 9 or adc1 it is simply missing.But it is recognised in CANbus scan and LVCAN200 can send it so it is definitely missing on server side .
Please check
162
Teltonika FM1100
aahero please write an email to hw@gurtam.com
Please clarify ID of your unit, mobile phone number of SIM card, and attach your current Teltonika configuration file and  your configurator.
Thanks.
163
Teltonika FM1100
just trying the same :-) LV200 with fuel level.
If the device is active, i will send you the data.
Wolf.
164
Teltonika FM1100
Wolf.
LVCAN200 is working fine I am just trying to get the same with FM1000
165
Teltonika FM1100
Hello guys.
We just got a client who already has some teltonika fm1100 devices for some time. When trying to configure them we get a "Enter pasword" request from the configurator. He has no ideea about the devices beeing password protected and the local company from where he bought them don't remember smile
Any ideea if there is a solution for resetting the password? Thanks
166
Teltonika FM1100
florin1 Ask teltonika who was a dealer (by IMEI) and contact this company.
167
Teltonika FM1100
Please help me.
Any body know the Applicable Type of Vehicles /TELTONIKA FM1000/
It's my life
168
Teltonika FM1100
(edited by b.chuka 31/07/2016 17:27:26)
Hello experts.
I don't know to install  teltonika fm1000 how many types of vehicles. Please tell me, Anybody know this. I need the list of Applicable Type of Vehicles /with CAN data, without CAN data/.
It's my life
169
Teltonika FM1100
Hi Everyone
Does anyone know what the syntax is for sending an i-button serial to an FM11XX unit?
Hope it can be done. Would be a pain to have to get hold of the vehicle every time.
Would appreciate anyone’s input.
Thanks,
170
Teltonika FM1100
Dear Friend,
       I try to add Teltonika FM1100 to my account. Firstly I configured FM1100 with server IP: 193.193.165.165 and port: 20412. Then I add new unit in my account by navigate to unit tab in account and click New, a popup window . I enter name , device type: Teltonika FM1100 and Unique ID: IMEI of device. Then I click Ok. No connection established between server and FM1100 device.
I try Gurtam GPS Device Unique ID Checker, but it also did not appear. I get configuration of GPRS form my GSM provider. Can any one help me. Firmware version of FM1100:  01.17.02.Rev:4
Thanks
171
Teltonika FM1100
ahmed.ibrahem  Can you please write to hw@gurtam.com. Describe your problem, and, please, add  device configuration file and device IMEI to letter. Thank you.
172
Teltonika FM1100
Is that possible to setup SMS command to cut of engine and then enable engine back in Teltonika FM1100 if yes please explain to me in details how?
Thanks in advance
173
Teltonika FM1100
username password setdigout 10 = set dout1 to 1
username password setdigout 00 = set dout1 to 0 (dout 2 also to 0)
Regards WOlf.
p.s. reading the manual always helps! If you start working with that HW you need to read it for sure
searching for "teltonika fm1100 manual pdf" in google brings on the first 25 URL manuals for the above device
174
Teltonika FM1100
To people that are successfully using Teltonika devices, may I ask what is the failure rate of FM1100 based on your personal experience ?
To people that had problems, what component failed: firmware (bug), cables and socket, antenna or whole device ?
175
Teltonika FM1100
Does any one can help me to connect FM1100 with 08.03.02
I have no configurator that connects it?
176
Teltonika FM1100
between 2% and 3% during 2 years.
Most devices lost their brain and could be just flashed with new firmware.
Some had broken modems and TT repaired them.
There are sometimes some bugs as with every software / hardware.
Overall rating: good HW, mostly good FW, Support is bad (must be via your Sales guy, no direct contact to support, if you have real problems its an endless email ping pong), If you need custom firmware, you need to pay a lot. But for this you get really low cost HW.
Depends on your needs. We just calculated all the negatives into the sourcing price and it was still much better than all alternatives...
Wolf.
177
Teltonika FM1100
(edited by glwi 20/02/2017 12:50:49)
between 2% and 3% during 2 years...
Hi Wolf and thank you for your valuable answer.
After some test with no particular problems, I'm planning to deploy many FM1100 to some clients, but I was looking for reliability data of users with a large installation base over a period of several years.
I agree with all your overall ratings points: the price / performance ratio is very good to find a competing alternative.
178
Teltonika FM1100
Some users on previous posts of this topic were talking about the ability of FM1100 to receive Gprs commands over the ip network when the device has an active connection.
I can confirm that I was able to send commands to the devices configured to transmit data in TCP mode but not using UDP.
Can someone please tell about their experience sending "Gprs" commands to FM1100 whit the device configured to transmit/receive data in udp mode ?
179
Teltonika FM1100
glwi This possibility isn't described in the protocol.
It seems that Teltonika doesn't support UDP commands.
180
Teltonika FM1100
Hi Yavi, maybe you being part of the Wialon support team can bring this to the attention of Teltonika.
It is just a matter of encapsulating the command data over Udp instead of Tcp ...
181
Teltonika FM1100
Glwi, i dont believe they will change this. FM1100 is already not in their product line
182
Teltonika FM1100
(edited by glwi 01/03/2017 17:59:17)
Hello Wolf,
FM1100 seem still on their product line: see this link
Either way, I think so, too, that they will not change the remote command protocol support.
183
Teltonika FM1100
Friends We have problems with FM1120 and FM1100 they dont send data to wialon, we are sure that we used right settings and param we used before but nothing happen. any one here have latest firmware and configurator for those devices?
With best regards
WTracking & Services, Lda
844747747
Rua 1301, Casa 61, Sommarschield1 Maputo
184
Teltonika FM1100
Hi Everyone,
We are having some problems with FM1120 and FM 1100 teltonika track devices. Those devices was installed in vehicles for long time and those vehicles was parked. now we decided to use them and devices are not update data we tried to change sim cards, run firmware update and configurator but still the same we still have same problem.
is there any one who can provide help with or who can provide new firmware and fm configurator for such devices?
With best regards
844747747
185
Teltonika FM1100
Hello
Dear Wtracking,
Could you connect device to your laptop and take terminal log ?(instructions below)
http://avl1.teltonika.lt/downloads/debu … %20LOG.pdf
Take 10-15 minute long log and send this info(log in and configurations) to Teltonika's sales manager, we will check what could be  wrong and solve it as soon as possible.
Best regards
Teltonika's support engineer
