Topic: Command execution status/state
Hi, I have a problem with getting the status of the executed command.
When I execute the command via unit/exec_cmd I'm getting no errors which mean command suppose to execute successfully. But in reality, Teltonika TST100 does nothing. I assume because Scooter (or electro bike) is off at that moment.
Is there any chance to check if the command is actually executed successfully?
Or maybe there is some command(s) that can help to determine whether the tracker is able to execute a command or not. Or is there a way to determine whether the tracker is online or not. I have already used https://sdk.wialon.host/wiki/en/sidebar/ … date_units and https://sdk.wialon.host/wiki/en/sidebar/ … ck_updates to check the latest actual data from the tracker. But even if I got real data within 1-2 minutes, which actually should mean that tracker is on, I still can't execute the command.
In my case command is lock/unlock tracker/vehicle
