WialonLocal. Sending a message which the logs say "no GPS, IO data"
(edited by rgamez 06/06/2018 02:08:20)
Topic: WialonLocal. Sending a message which the logs say "no GPS, IO data"
Hi!
I'm working with wialon local and I have a console that retrieves information from a webpage and send it through udp to our server.
The thing is that I can't seem to make it work. I configure everything right on the message I send but the server logs of the device reads:
     2018/06/05 22:27:01:339: GPRS MSG(Gosafe G91I): ID: 1232735717, IP: --------, MSG: TIME: 17:26:49, no GPS, IO data
I even copy the information of a message that worked and just changed the date and deviceid and still doesn't work. For example
Message that worked:
24-96-51-11-07-10-14-32-41-23-01-17-25-40-40-20-00-10-01-80-11-84-00-00-00-FF-FF-FB-FF-FF-00-85-10-47-95-76-86-00-00-00-00-00-00-00-00-00-00-70
Message that doesn't work:
24-12-32-73-57-17-17-35-22-05-06-18-25-40-40-20-00-10-01-80-11-84-00-00-00-FF-FF-FB-FF-FF-00-85-10-47-95-76-86-00-00-00-00-00-00-00-00-00-00-70
The device I'm using is a Gosafe G91I.
I hope some one from Gurtam can help me in this case.
